[geos-devel] Delocalizing the WKT writer?
sgillies at frii.com
Thu Aug 28 12:43:39 EDT 2008
Can one of the C++ gurus explain why delocalizing the writer (to fix bug
201) isn't as simple as bracing the guts of this function with calls to
setlocale()?
capi/geos_c.cpp:
char*
GEOSWKTWriter_write(WKTWriter *writer, const Geometry *geom)
try
// switch to C locale
std::setlocale(LC_ALL, "C");
std::string s = writer->write(geom);
char *result;
result = (char*) std::malloc( s.length() + 1);
std::strcpy(result, s.c_str() );
// switch back to native locale
std::setlocale(LC_ALL, "");
return result;
catch (const std::exception &e)
ERROR_MESSAGE("%s", e.what());
return NULL;
catch (...)
ERROR_MESSAGE("Unknown exception thrown");
return NULL;
Sure, it would be nice to work this down into the C++ code, but the
WKTWriter class is a nightmare.
Sean
