[geos-devel] Thread Safe CAPI next steps?
Chuck Thibert charles.thibert at ingres.com
Fri Dec 19 14:14:19 EST 2008
Just wanted to be sure since all that is compiled into the unit test
executable.  I don't think these tests go into the unit test tool but I
have no problem putting them there and compiling into the separate tools
if there are no objections.
Chuck
On Fri, 2008-12-19 at 08:50 -0800, Paul Ramsey wrote:
> I would hazard tests/capi
> Other thoughts?
> P
> On Fri, Dec 19, 2008 at 8:31 AM, Chuck Thibert
> <charles.thibert at ingres.com> wrote:
> > Got the other comments worked out but I have a couple questions about
> > moving the test programs.
> > 1) The original test program, geostest.c has been there all along.  The
> > new ones I added were copies of geostest.c.  Should everything be moved?
> > 2) Where in the tests directory should they go? They aren't currently
> > part of the unit testing.
> > Thanks,
> > Chuck
> > On Wed, 2008-12-17 at 21:25 -0800, Paul Ramsey wrote:
> >> On Wed, Dec 17, 2008 at 9:07 PM, Paul Ramsey <pramsey at cleverelephant.ca> wrote:
> >> > - Also not glad to see the test programs in the midst of the other
> >> > stuff. Subdir it?
> >> No, really, in ./tests would be best. To answer myself.
> >> P
> >> _______________________________________________
> >> geos-devel mailing list
> >> geos-devel at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/geos-devel
