[geos-devel] Minimum Bounding Circle
Martin Davis
mbdavis at refractions.net
Mon Dec 29 13:14:55 EST 2008
Yes, this is computing the same thing as the Minimum Bounding Circle
algorithm. This algorithm appeared in JTS for some reason which is lost
in the mists of time. AFAIK it's never really been used or tested
extensively.
It probably postdated the initial port of GEOS, and I guess nobody went
looking for it until now...
Obe, Regina wrote:
> I was snooping around the GEOS library and noticed a curious algorithm
> class
> called MinimumDiameter. As far as I can tell from scanning the code,
> it seems similar in concept to the the Minimum Bounding Circle plpgsql
> algorithm that
> Bruce posted in November
> http://postgis.refractions.net/pipermail/postgis-users/2008-October/021734.html
> Just wondering why this is not exposed in the CAPI interface or does
> it server an entirely different purpose from what I am thinking.
> Thanks,
> Regina
> *The substance of this message, including any attachments, may be
> confidential, legally privileged and/or exempt from disclosure
> pursuant to Massachusetts law. It is intended solely for the
> addressee. If you received this in error, please contact the sender
> and delete the material from any computer. *
> * Help make the earth a greener place. If at all possible resist
> printing this email and join us in saving paper. *
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geos-devel
Martin Davis
Senior Technical Architect
Refractions Research, Inc.
(250) 383-3022
