[geos-devel] Bug in buffer function?
Silke Reimer reimer at rapideye.de
Wed Feb 6 07:50:46 EST 2008
Hallo again,
I know that usually it is not really helpful to submit a request twice but in
this case I give it a try by formulating the request slightly different: Can
anybody please try just to through the below mentioned polygons into the
corresponding geos function and confirm the behavior? All I want to know is,
whether this is really a bug or whether I just oversee something.
(If I get no answer to this email I will just add this example to the bug
tracker.)
Thanks,
	Silke
See here again the original post:
On Friday 25 January 2008, Silke Reimer wrote:
> Hallo!
> I observed a really strange behavior of the buffer function when using an
> inner buffer. The error occurs with the following geometry:
> POLYGON ((
> 513.4 343.1,
> 707.3 344.2,
> 707.0 394.9,
> 797.9 395.4,
> 799.2 341.8,
> 516.9 340.9,
> 516.7 262.3,
> 513.2 262.3,
> 513.4 343.1
> Its WKB representation is
> 0103000000010000000900000033333333330B80409A9999999971754066666666661A86403
>33333333383754000000000001886406666666666AE78403333333333EF88406666666666B67
>8409A99999999F98840CDCCCCCCCC5C7540333333333327804066666666664E75409A9999999
>9258040CDCCCCCCCC6470409A99999999098040CDCCCCCCCC64704033333333330B80409A999
>99999717540
> Using a buffer of -2 should lead to an inner buffer but leads
> to "GEOMETRYCOLLECTION EMPTY" resp. "POLYGON( EMPTY)" depending on the geos
> version.
> Using the same buffer of -2 on a polygon with the same shape but shifted to
> the left by 100 and shifted down by 100, i.e.
> POLYGON ((
> 413.4 243.1,
> 607.3 244.2,
> 607.0 294.9,
> 697.9 295.4,
> 699.2 241.8,
> 416.9 240.9,
> 416.7 162.3,
> 413.2 162.3,
> 413.4 243.1
> resp.
> 010300000001000000090000006666666666D679403333333333636E406666666666FA82406
>666666666866E400000000000F8824066666666666E72403333333333CF85406666666666767
>2409A99999999D985409A99999999396E4066666666660E7A40CDCCCCCCCC1C6E40333333333
>30B7A409A999999994964403333333333D379409A999999994964406666666666D6794033333
>33333636E40
> leads to the expected buffer:
> POLYGON((609.172261037685 243.512992930268,609.26383338939
> 243.821372982058,609.29996498814 244.211834112356,609.011804031568
> 292.911035772954,695.948180429531 293.389233662932,697.151062564334
> 243.793477951075,609.172261037685 243.512992930268))
> resp.
> 01030000000100000007000000DD1965CA600983408D5226706A706E403118AE541C0A83402
>AF8FDAF487A6E400A300B54660A8340DB175558C7866E405E4CB62C1808834035253F9A934E7
>2405BFC9EDF95BF8540BECC134D3A567240B72B4A6035C98540EB3EDF2B64796E40DD1965CA6
> I tested this on different geos versions among them
> 3.0.0rc4 and 3.0.0
> I would say that this is a bug but it would be nice if somebody could
> confirm this - and perhaps you even have an idea how to solve this? I did
> not find any entry in the bug tracker but maybe I just missed it. In this
> case I would be glad for a hint.
> Many greetings,
> 	Silke
phone: +49 3381 8904318		 fax:   +49 3381 8904101
RapidEye AG
Molkenmarkt 30
14776 Brandenburg an der Havel
Germany
Head Office/Sitz der Gesellschaft: Brandenburg an der Havel
Management Board/Vorstand: Wolfgang G. Biedermann
Chairman of Supervisory Board/Vorsitzender des Aufsichtsrates: Axel Schmalz
Commercial Register/Handelsregister Potsdam HRB 17 796
Tax Number/Steuernummer: 048/100/00053
VAT-Ident-Number/Ust.-ID: DE 199331235
Diese E-Mail enthaelt vertrauliche und/oder rechtlich geschuetzte
Informationen. Wenn Sie nicht der richtige Adressat sind oder diese
E-Mail irrtuemlich erhalten haben, informieren Sie bitte sofort den
Absender und vernichten Sie diese E-Mail. Das unerlaubte Kopieren sowie
die unbefugte Weitergabe dieser E-Mail ist nicht gestattet.
The information in this e-mail is intended for the named recipients
only. It may contain privileged and confidential information. If you
have received this communication in error, any use, copying or
dissemination of its contents is strictly prohibited. Please erase all
copies of the message along with any included attachments and notify
RapidEye AG or the sender immediately by telephone at the number
indicated on this page.
