[geos-devel] GEOS 3 DLLs?
Artem Pavlenko
artem.mapnik at googlemail.com
Mon Jan 14 11:58:16 EST 2008
Hi Sean,
> Artem,
> My user is unable to load these DLLs on a new Vista system.
> Microsoft Visual C++ Runtime Library
> Runtime Error!
> Program: C:\Python25\python.exe
> R6034
> An application has made an attempt to load the C runtime library
> incorrectly.
> Please contact the application's support team for more information.
> OK
> Could it be a missing manifest?
It might well be the manifest. Let me check...
Artem
> Sean
> Artem Pavlenko wrote:
>> Hi Sean,
>> You can get geos 3 dlls (+libs) from :
>> http://artem.dev.openstreetmap.org/files/geos_3.zip
>> Or you can always build them yourself using VC++ express (free as
>> in beer):
>> nmake /f Makefile.vc
>> HTH
>> Cheers
>> Artem
>> On 12 Jan 2008, at 21:07, Sean Gillies wrote:
>>> Can anyone share GEOS 3 DLLs (including the C API) with me? I
>>> tried to
>>> get them out of the PostGIS 1.3.2 installer, but that appeared to
>>> require installing Postgres and I'm unwilling to do that.
>>> Thanks,
>>> Sean
>>> geos-devel mailing list
>>> geos-devel at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/geos-devel
