[geos-devel] GEOS 3 DLLs?
Artem Pavlenko artem.mapnik at googlemail.com
Mon Jan 14 12:12:33 EST 2008
On 14 Jan 2008, at 17:02, Charlie Savage wrote:
>> Could it be a missing manifest?
> That is almost always the issue I run into.  VC 2005 will embed the
> manifest for you, but I'm not sure if the Express versions do and
> nmake definitely does not.
> To fix, use the mt command link tool to embed the manifest:
> http://msdn2.microsoft.com/en-us/library/ms235591.aspx
I found this one, too:
http://msdn2.microsoft.com/en-us/library/ms235591(VS.80).aspx
OK, I embedded manifests into geos.dll and geos_c.dll, could you try ?
http://artem.dev.openstreetmap.org/files/geos_c.dll
http://artem.dev.openstreetmap.org/files/geos.dll
Joy of windows dev :)
Artem
> Charlie
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geos-devel
