[geos-devel] geos make check fails
Eric Knappe
ericknappe at gmail.com
Thu Jan 17 00:02:51 EST 2008
Paul,
A segmentation fault caused make check to FAIL.
./configure --prefix=/home/mydir
make
make check
The tail of the output from make check is this:
FAIL: testrunner
1 of 1 tests failed
make[2]: *** [check-TESTS] Error 1
make[2]: Leaving directory `/usr/home/mydir/geos-3.0.0/capi'
make[1]: *** [check-am] Error 2
make[1]: Leaving directory `/usr/home/mydir/geos-3.0.0/capi'
make: *** [check-recursive] Error 1
[mydir][~/geos-3.0.0]$
In looking through the output of make check I found the listing below:
Is it odd that geostest is up to date here?
Is it odd to see "GEOS version 3.0.0rc2-CAPI"?
Making check in capi
make[1]: Entering directory `/usr/home/mydir/geos-3.0.0/capi'
make geostest
make[2]: Entering directory `/usr/home/mydir/geos-3.0.0/capi'
make[2]: `geostest' is up to date.
make check-TESTS
./testrunner: line 2: 4800 Segmentation fault ./geostest ./test.wkt >
test.out
geostest exited with non-zero status (139)
1,25d0
< GEOS version 3.0.0rc2-CAPI-1.3.0
I found some warnings in the make output:
if /bin/sh ../libtool --tag=CXX --mode=compile g++ -DHAVE_CONFIG_H -I. -I.
-I../ source/headers -I../source/headers/geos
-I../source/headers -DGEOS_CAPI_VERSION= '"
3.0.0-CAPI-1.4.1"' -DGEOS_JTS_PORT='"1.7.1"' -g -O2 -DGEOS_INLINE -Wall
-ans i -pedantic -Wno-long-long -MT
libgeos_c_la-geos_c.lo -MD -MP -MF ".deps/libgeos
_c_la-geos_c.Tpo" -c -o libgeos_c_la-geos_c.lo `test -f 'geos_c.cpp' || echo
'./ '`geos_c.cpp; \
then mv -f ".deps/libgeos_c_la-geos_c.Tpo" ".deps/libgeos_c_la-geos_c.Plo";
else rm -f ".deps/libgeos_c_la-geos_c.Tpo"; exit
1; fi
mkdir .libs
g++ -DHAVE_CONFIG_H -I. -I. -I../source/headers -I../source/headers/geos
-I../s ource/headers -DGEOS_CAPI_VERSION=\"
3.0.0-CAPI-1.4.1\" -DGEOS_JTS_PORT=\"1.7.1\" -g
-O2 -DGEOS_INLINE -Wall -ansi -pedantic -Wno-long-long -MT
libgeos_c_la-geos _c.lo -MD -MP -MF
.deps/libgeos_c_la-geos_c.Tpo -c geos_c.cpp -fPIC -DPIC -o
.l ibs/libgeos_c_la-geos_c.o
geos_c.cpp: In function `int GEOSWKBWriter_getOutputDimension(const
GEOSWKBWrite r*)':
geos_c.cpp:2207: warning: converting to non-pointer type `int' from NULL
geos_c.cpp: In function `int GEOSWKBWriter_getByteOrder(const
GEOSWKBWriter*)':
geos_c.cpp:2236: warning: converting to non-pointer type `int' from NULL
geos_c.cpp: In function `char GEOSWKBWriter_getIncludeSRID(const
GEOSWKBWriter*) ':
geos_c.cpp:2265: warning: converting to non-pointer type `char' from NULL
.deps/libgeos_c_la-geos_c.Tpo -c geos_c.cpp -o
libgeos_c_la-ge os_c.o >/dev/null 2>&1
creating XMLTester
if g++ -DHAVE_CONFIG_H -I. -I. -I../../source/headers
-I../../source/headers/geo s
-I../../source/headers -I../../source/io/markup -g -O2 -DGEOS_INLINE
SimpleWKTTester.o -MD -MP -MF ".deps/SimpleWK
TTester.Tpo" -c -o SimpleWKTTester.o SimpleWKTTester.cpp; \
then mv -f ".deps/SimpleWKTTester.Tpo" ".deps/SimpleWKTTester.Po"; else rm
-f ". deps/SimpleWKTTester.Tpo"; exit 1; fi
In file included from SimpleWKTTester.cpp:23:
../../source/headers/geos/io.h:61:2: warning: #warning is a GCC extension
../../source/headers/geos/io.h:61:2: warning: #warning *** DEPRECATED: You
are u sing deprecated header io.h. Please, update
your sources according to new layout of GEOS
headers and namespaces
In file included from SimpleWKTTester.cpp:24:
../../source/headers/geos/geom.h:145:2: warning: #warning is a GCC extension
../../source/headers/geos/geom.h:145:2: warning: #warning *** DEPRECATED:
You ar e using deprecated header geom.h. Please,
update your sources according to new l ayout of
GEOS headers and namespaces
/bin/sh ../../libtool --tag=CXX --mode=link g++ -g -O2 -DGEOS_INLINE -Wall
-ans i -pedantic -Wno-long-long -o
SimpleWKTTester SimpleWKTTester.o ../../source/
libgeos.la ../../source/libgeos.la
g++ -g -O2 -DGEOS_INLINE -Wall -ansi -pedantic -Wno-long-long -o
.libs/SimpleWKT Tester SimpleWKTTester.o
../../source/.libs/libgeos.so
creating SimpleWKTTester
Thanks
URL: http://lists.osgeo.org/pipermail/geos-devel/attachments/20080117/58db7c9a/attachment-0001.html
