[geos-devel] GEOS on Openmoko
Mateusz Loskot
mateusz at loskot.net
Tue Jul 22 12:06:03 EDT 2008
Greg Troxel wrote:
> 2.2.3: It looks like you don't have adequate C++ support on the target.
> I am unclear on if the C++ part is optional or core, and if you can turn
> it off.
> In file included from Coordinate.cpp:16:
> ../../source/headers/geos/geom.h:20:18: error: memory: No such file or directory
> ../../source/headers/geos/geom.h:21:20: error: iostream: No such file
> or directory
> ../../source/headers/geos/geom.h:22:18: error: string: No such file or directory
> ../../source/headers/geos/geom.h:23:18: error: vector: No such file or directory
> ../../source/headers/geos/geom.h:24:21: error: algorithm: No such file
> or directory
> ../../source/headers/geos/geom.h:25:15: error: map: No such file or directory
> ../../source/headers/geos/geom.h:26:17: error: cmath: No such file or directory
Joseph,
Greg is correct. You have not properly installed C++ compiler and C++
Standard Library. What version of C++ compiler do you use?
Greg,
GEOS core is written in C++, so there is no way to disable C++ part.
Regards
Mateusz Loskot, http://mateusz.loskot.net
Charter Member of OSGeo, http://osgeo.org
