[geos-devel] compile errors using VS 2005
Clay, Bruce
bclay at ball.com
Wed May 7 09:54:42 EDT 2008
I have tried to compile both version of GEOS as well as the packaged
nightly builds on WinXP using Visual Studio 2005. None of them will
build. Each try gives various responses. The errors shown below are
for the nightly build package.
First the compile errors
Commented geom\prep\PreparedPolygonLineIntersection.obj out of
makefile.vc because the file does not exist.
MCIndexNoder.inl and geos/noding/SegmentString.inl files are not
included so I copied them from version 3.0.0
Bruce
This message and any enclosures are intended only for the addressee. Please
notify the sender by email if you are not the intended recipient. If you are
not the intended recipient, you may not use, copy, disclose, or distribute this
message or its contents or enclosures to any other person and any such actions
may be unlawful. Ball reserves the right to monitor and review all messages
and enclosures sent to or from this email address.
URL: http://lists.osgeo.org/pipermail/geos-devel/attachments/20080507/ac946845/attachment.html
