[geos-devel] [GEOS] #216: WKBWriter does not write 3D values
correctly
geos-trac at osgeo.org
Wed Nov 19 14:58:29 EST 2008
#216: WKBWriter does not write 3D values correctly
Reporter: jbronn | Owner: geos-devel at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 3.1
Component: Core | Version: svn-trunk
Severity: Critical | Keywords: wkbwriter 3d z
I've been having much difficulty with the `WKBWriter` class as I could not
get it to produce correct 3D WKB/HEX values. Turns out that
`WKBWriter::writeCoordinate` ''always'' outputs the X value in place of
the Z coordinate.
Attached is a patch and a C API demonstration of the problem.
Ticket URL: <http://trac.osgeo.org/geos/ticket/216>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
