[geos-devel] [GEOS] #217: WKBReader does not set Z value on Point geometries
GEOS geos-trac at osgeo.org
Thu Nov 20 16:18:38 EST 2008
 Reporter:  jbronn       |       Owner:  geos-devel at lists.osgeo.org
     Type:  defect       |      Status:  new
 Priority:  major        |   Milestone:
Component:  Core         |     Version:  svn-trunk
 Severity:  Significant  |    Keywords:  wkbreader 3d z readPoint wkb
 `WKBReader::readPoint` only supports reading in 2D points.  Attached is
 patch that fixes it and a typo in the debugging code.
Ticket URL: <http://trac.osgeo.org/geos/ticket/217>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
