[geos-devel] Re: [GEOS] #208: Provide alternate malloc/free at run
time
geos-trac at osgeo.org
Sat Oct 4 14:15:01 EDT 2008
#208: Provide alternate malloc/free at run time
Reporter: pramsey | Owner: geos-devel at lists.osgeo.org
Type: enhancement | Status: closed
Priority: major | Milestone: 3.1
Component: Default | Version: svn-trunk
Severity: Unassigned | Resolution: wontfix
Keywords: |
Changes (by pramsey):
* status: new => closed
* resolution: => wontfix
Comment:
Using a PostgreSQL trick from Mark Cave-Ayland, this is no longer a
critical issue for PostGIS, so this idea is being shelved until someone
else has an existential need for it.
Ticket URL: <http://trac.osgeo.org/geos/ticket/208#comment:1>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
