[geos-devel] RFC for Thread safe CAPI announced
Howard Butler
hobu.inc at gmail.com
Fri Oct 17 15:25:03 EDT 2008
On Oct 17, 2008, at 2:06 PM, Frank Warmerdam wrote:
> I'd add that I'd like the RFC to define the context of the context
> structure. I also think that the application visible handle should be
> declared:
> type void *GEOSContextHandle_t;
I would suggest we change this to:
typedef struct GEOSContextHandle_HS *GEOSContextHandle_t;
which makes it easier for the compiler to catch when we pass in an
incorrect pointer. For GDAL/OGR, if you compile with -DDEBUG, this
pattern is currently applied, but it is not otherwise because we
didn't want to risk breaking existing client code.
Howard
