[geos-devel] 3.0.3 To Do
Obe, Regina robe.dnd at cityofboston.gov
Wed Oct 22 15:04:56 EDT 2008
Didn't Mark Cave-Ayland already do that and say it worked?
From: geos-devel-bounces at lists.osgeo.org on behalf of Paul Ramsey
Sent: Wed 10/22/2008 3:03 PM
To: GEOS Development List
Subject: Re: [geos-devel] 3.0.3 To Do
You're right, the removal of strdup was in your patch already... so, I
guess we just need a Windoze volunteer to compile branch 3.0.
P.
On Wed, Oct 22, 2008 at 11:58 AM, Obe, Regina <robe.dnd at cityofboston.gov> wrote:
> Wasn't the CLocalizer change in trunk already.  It should have been in my
> patch since I took the CLocalizer.cpp and .h from trunk since I couldn't get
> it to compile otherwise.  Or hmm I think I that was the one that I couldn't
> just add the header line.
> Sent: Wed 10/22/2008 2:57 PM
> Subject: [geos-devel] 3.0.3 To Do
> Well, that was fast...
> I've applied Regina's patch so we should compile under new GCC and
> hopefully Windows too? We have a patch to CLocalizer that needs to go
> in and be tested on Windows.
> Sean, how about you commit the patch and then we can have the Windows
> people test off of SVN. If it's not working we can fix it up post
> facto.
> Is there anything else outstanding on the 3.0 branch standing in front
> of another point release?
> Paul
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geos-devel
> The substance of this message, including any attachments, may be
> confidential, legally privileged and/or exempt from disclosure pursuant to
> Massachusetts law. It is intended solely for the addressee. If you received
> this in error, please contact the sender and delete the material from any
> computer.
> Help make the earth a greener place. If at all possible resist printing this
> email and join us in saving paper.
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
URL: http://lists.osgeo.org/pipermail/geos-devel/attachments/20081022/b183cc66/attachment-0001.html
