[geos-devel] 3.0.3 To Do
Hartmut Kaiser hartmut.kaiser at gmail.com
Wed Oct 22 15:55:01 EDT 2008
> You're going to miss some minor dramas if you keep on sleeping like
> this
> He did test on mingw but not Visual C++.  Think we need a Visual C++
> tester.  I presume it should compile in that.  I would myself, but
> haven't quite figured out how that side of Visual Studio works.
> http://postgis.refractions.net/pipermail/postgis-devel/2008-
> October/0039
> 67.html
I can do that later today.
Regards Hartmut
> Though he did say GeoJSON regression test fails.
> -----Original Message-----
> From: geos-devel-bounces at lists.osgeo.org
> [mailto:geos-devel-bounces at lists.osgeo.org] On Behalf Of Paul Ramsey
> Sent: Wednesday, October 22, 2008 3:11 PM
> To: GEOS Development List
> Subject: Re: [geos-devel] 3.0.3 To Do
> No, I'm pretty sure he said he'd do it when he got time.
> P
> On Wed, Oct 22, 2008 at 12:04 PM, Obe, Regina
> <robe.dnd at cityofboston.gov> wrote:
> > Didn't Mark Cave-Ayland already do that and say it worked?
> > ________________________________
> > From: geos-devel-bounces at lists.osgeo.org on behalf of Paul Ramsey
> > Sent: Wed 10/22/2008 3:03 PM
> > You're right, the removal of strdup was in your patch already... so,
> I
> > guess we just need a Windoze volunteer to compile branch 3.0.
> > P.
> > On Wed, Oct 22, 2008 at 11:58 AM, Obe, Regina
> > wrote:
> >> Wasn't the CLocalizer change in trunk already.  It should have been
> in my
> >> patch since I took the CLocalizer.cpp and .h from trunk since I
> couldn't
> >> get
> >> it to compile otherwise.  Or hmm I think I that was the one that I
> >> couldn't
> >> just add the header line.
> >> Sent: Wed 10/22/2008 2:57 PM
> >> Subject: [geos-devel] 3.0.3 To Do
> >> Well, that was fast...
> >> I've applied Regina's patch so we should compile under new GCC and
> >> hopefully Windows too? We have a patch to CLocalizer that needs to
> go
> >> in and be tested on Windows.
> >> Sean, how about you commit the patch and then we can have the
> Windows
> >> people test off of SVN. If it's not working we can fix it up post
> >> facto.
> >> Is there anything else outstanding on the 3.0 branch standing in
> front
> >> of another point release?
> >> Paul
> >> _______________________________________________
> >> geos-devel mailing list
> >> geos-devel at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/geos-devel
> >> The substance of this message, including any attachments, may be
> >> confidential, legally privileged and/or exempt from disclosure
> pursuant to
> >> Massachusetts law. It is intended solely for the addressee. If you
> >> received
> >> this in error, please contact the sender and delete the material
> from
> any
> >> computer.
> >> Help make the earth a greener place. If at all possible resist
> printing
> >> this
> >> email and join us in saving paper.
> pursuant to
> received
> > this in error, please contact the sender and delete the material from
> any
> > computer.
> printing this
> pursuant to Massachusetts law. It is intended
> solely for the addressee. If you received this in error, please
> contact the sender and delete the material from any computer.
