[geos-devel] 3.0.3 To Do
Obe, Regina robe.dnd at cityofboston.gov
Thu Oct 23 10:30:21 EDT 2008
I tried Sanak's patch on my Visual Studio 2005 Professional install, and
it seemed to fix my compile problems.
Also ran the tests and they all seemed to pass - test output below in
case I misread something.
I know Frank already tested on Visual C++ Express (which is basically
Visual 2008 Express) and got some test fail errors.  Do we have a
solution file for that (or would people just use the msvc80 solution
file for that if they wanted to use a solution) .
I have another box in my office that has VS 2008 Professional on it (and
I think I loaded VC++ on it) that I can test later on in the day.  Just
not sure if to use the msvc80 solution or if have to use the makefile.vc
that Frank patched which I have no clue how to use.
As far as the solution file - I couldn't test the geos_ruby since I
don't have that installed - so maybe someone can test that out.  The
geos_python seemed to compile fine too.
Thanks,
Regina
 	Linking...
   Creating library
D:\SVNProjects\geos\3.0\build\msvc80\Debug\geos_unitd.lib and object
D:\SVNProjects\geos\3.0\build\msvc80\Debug\geos_unitd.exp
Embedding manifest...
Running regression tests using geos_unitd.exe...
  GEOS Test Suite Application
capi::GEOSCoordSeq: ..... 5
capi::GEOSSimplify: . 1
geos::algorithm::CGAlgorithms::computeOrientation: .. 2
geos::algorithm::CGAlgorithms::isCCW: ... 3
geos::algorithm::CGAlgorithms::isPointInRing: .. 2
geos::algorithm::ConvexHull: ....... 7
geos::algorithm::PointLocator: .... 4
geos::geom::Coordinate: ......... 9
geos::geom::CoordinateArraySequence: ............... 15
geos::geom::CoordinateArraySequenceFactory: .... 4
geos::geom::CoordinateList: . 1
geos::geom::Dimension: ..... 5
geos::geom::Envelope: ......... 9
geos::geom::Geometry::covers: ... 3
geos::geom::Geometry::isRectangle: ....... 7
geos::geom::GeometryFactory: ................................... 35
geos::geom::IntersectionMatrix: ............................. 29
geos::geom::LineSegment: ...... 6
geos::geom::LineString: ......................... 25
geos::geom::LinearRing: .............................. 30
geos::geom::Location: ... 3
geos::geom::MultiLineString: . 1
geos::geom::MultiPoint: ............................ 28
geos::geom::MultiPolygon: . 1
geos::geom::Point: ....................................... 39
geos::geom::Polygon: ..................................... 37
geos::geom::Triangle: ..... 5
geos::index::quadtree::DoubleBits: . 1
geos::io::ByteOrderValues: ... 3
geos::io::WKBReader: ....... 7
geos::noding::SegmentNode: . 1
geos::noding::SegmentPointComparator: . 1
geos::noding::SegmentString: .... 4
geos::operation::IsSimpleOp: ... 3
geos::operation::distance::DistanceOp: ................ 16
geos::operation::overlay::FuzzyPointLocator: ....... 7
geos::operation::overlay::OffsetPointGenerator: ..... 5
geos::operation::overlay::OverlayResultValidator: ...... 6
geos::precision::GeometrySnapper: .. 2
geos::precision::LineStringSnapper: .. 2
geos::precision::SimpleGeometryPrecisionReducer: ....... 7
geos::simplify::DouglasPeuckerSimplifier: .......... 10
geos::simplify::TopologyPreservingSimplifier: .......... 10
geos::util::UniqueCoordinateArrayFilter: . 1
Tests summary:
 - passed: 402
[mailto:geos-devel-bounces at lists.osgeo.org] On Behalf Of Sanak
Sent: Thursday, October 23, 2008 7:33 AM
To: GEOS Development List
Subject: Re: [geos-devel] 3.0.3 To Do
CLocalizer source/header needs in /build/msvc80/geos_lib/geos_lib.vcproj
file.
Please refer the attach file(geos-branches-3.0-build-msvc80.patch).
Regards,
2008/10/23 Paul Ramsey <pramsey at cleverelephant.ca>
	Well, that was fast...
	I've applied Regina's patch so we should compile under new GCC
and
	hopefully Windows too? We have a patch to CLocalizer that needs
to go
	in and be tested on Windows.
	Sean, how about you commit the patch and then we can have the
Windows
	people test off of SVN. If it's not working we can fix it up
post
	facto.
	Is there anything else outstanding on the 3.0 branch standing in
front
	of another point release?
	Paul
	geos-devel mailing list
	geos-devel at lists.osgeo.org
	http://lists.osgeo.org/mailman/listinfo/geos-devel
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
URL: http://lists.osgeo.org/pipermail/geos-devel/attachments/20081023/58b7f1d4/attachment.html
