[geos-devel] 3.0.3 To Do
Paul Ramsey pramsey at cleverelephant.ca
Thu Oct 23 23:41:45 EDT 2008
I couldn't apply this patch cleanly, could someone else try?
P.
On Thu, Oct 23, 2008 at 10:52 AM, Sanak <geosanak at gmail.com> wrote:
> Ok, I had added geostest project to msvc80 solution file.
> Please see the attach
> file(geos-branches-3.0-build-msvc80_add_geostest.patch).
> geostest.vcproj will generate capi/test.out.
> I think that the cause of difference between generated test.out and
> test.expected is precision of floating point, but I don't know details.
> And another Visual C++ specific problem may be capi
> version.(capi/geos_c.h.in)
> Index: geos_c.h.in
> --- geos_c.h.in    (revision 2208)
> +++ geos_c.h.in    (working copy)
> @@ -51,9 +51,9 @@
>  #if defined(_MSC_VER)
>  #include <geos/version.h>
>  #define GEOS_CAPI_VERSION_MAJOR 1
> -#define GEOS_CAPI_VERSION_MINOR 3
> +#define GEOS_CAPI_VERSION_MINOR 4
>  #define GEOS_CAPI_VERSION_PATCH 3
> -#define GEOS_CAPI_VERSION "3.0.0rc4-CAPI-1.3.3"
> +#define GEOS_CAPI_VERSION "3.0.3-CAPI-1.4.3"
>  #else
>  #define GEOS_VERSION_MAJOR @VERSION_MAJOR@
>  #define GEOS_VERSION_MINOR @VERSION_MINOR@
> Regards,
> 2008/10/24 Frank Warmerdam <warmerdam at pobox.com>
>> Obe, Regina wrote:
>>> I know Frank already tested on Visual C++ Express (which is basically
>>> Visual 2008 Express) and got some test fail errors.  Do we have a solution
>>> file for that (or would people just use the msvc80 solution file for that if
>>> they wanted to use a solution) .
>>> Running regression tests using geos_unitd.exe...
>>>  GEOS Test Suite Application
>>> capi::GEOSCoordSeq: ..... 5
>>> capi::GEOSSimplify: . 1
>> Folks,
>> I would note that I wasn't running geos_unitd.exe, I ran geostest.exe
>> against capi/test.wkt and compared to capi/test.expected.  If I get
>> back to my windows build I'll look into the geos_unitd.exe which I wasn't
>> aware of.
>> Best regards,
>> I set the clouds in motion - turn up   | Frank Warmerdam,
>> light and sound - activate the windows | http://pobox.com/~warmerdam
>> and watch the world go round - Rush    | Geospatial Programmer for Rent
>> geos-devel mailing list
>> geos-devel at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geos-devel
