[geos-devel] RE: [postgis-devel] Geos Capi OverlayOp, overlayOp question
Obe, Regina robe.dnd at cityofboston.gov
Wed Sep 17 08:13:59 EDT 2008
Mateusz,
> Are you asking about the redundant "using" directive or about use of
> "using" directive in general?
Mostly the redundant using.  I wasn't sure if there was some mysterious
class I was missing. I assume using in C++ plays the same role as it
does in C#.
Thanks,
Regina
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
