[geos-devel] Unclear objects lifetime and ownership issues in Monotone Chain components
Mateusz Loskot mateusz at loskot.net
Wed Sep 24 17:52:34 EDT 2008
strk wrote:
> On Wed, Sep 24, 2008 at 10:50:59PM +0200, Mateusz Loskot wrote:
>> So, tracking objects ownership and flows is very hard.
>> How do we know all users of given pool in given time (without
>> reading the whole codebase).
> Which is another well known problem: there are too many interfaces
> exposed. My solution was: warranty void if you don't use the C-API.
I don't have much comments on GEOS interfaces.
> So you'd basically follow the flow from C-API on.
Facing this particular problem, I am not how higher-level API
may help to solve low-level issues :-)
> The wider your pools, the more issues with memory and time boundaries.
> The closer-to-low-level-op you pool the better.
Probably right.
Anyway, I have to confess I feel powerless to solve it.
Best regards,
Mateusz Loskot
http://mateusz.loskot.net
