[geos-devel] Unclear objects lifetime and ownership issues in
Monotone Chain components
Martin Davis
mbdavis at refractions.net
Thu Sep 25 12:05:01 EDT 2008
Mateusz,
IMO you're on the right track with the idea that
MCIndexSegmentSetMutualIntersector owns the segChains that it
allocates. They can be deleted in it's destructor.
I don't see the design problem. What's wrong with having complex
long-lived structures which allocate internal objects, and then free
them when the structure is itself destroyed?
Mateusz Loskot wrote:
> Folks,
> I've started memory leaks cleanup [1] in GEOS and found quite serious
> design issue around MonotoneChain components.
> Here is longer story [2] with suggested solution, however I'm not enough
> knowledgeable about all internals especially about possible relations
> between various collections allocated internally as well as flows and
> ownership transfers.
> I'd be thankful if original authors of these components (Ben?, Sandro?)
> could share their minds.
> [1] http://trac.osgeo.org/geos/ticket/207
> [2] http://trac.osgeo.org/geos/ticket/207#comment:4
> Best regards,
Martin Davis
Senior Technical Architect
Refractions Research, Inc.
(250) 383-3022
