[geos-devel] Unclear objects lifetime and ownership issues in
Monotone Chain components
Martin Davis
mbdavis at refractions.net
Thu Sep 25 20:23:43 EDT 2008
Mark Cave-Ayland wrote:
> Martin, would there ever be a case where a hidden internal object could
> be shared between multiple parent objects?
Um... I'll say no, this is not a pattern which is intentionally used in
JTS *at the level at which user functionality is concerned*. Of course,
in the internal graph structures there is lots of cross-pointing, but
the lifetime of these structures is always well-defined.
In general, if the goal is to expose the methods on Geometry which are
used in PostGIS, then it should be possible to free all allocated memory
when the method completes (apart from any returned geometry, of
course). The one new exception to this is the PreparedGeometry classes,
which of course have to hold onto memory for their internal structures.
But their lifetime is well-defined as well.
Hopefully that helps. Is there a possibility of supplying a single pool
to each new Geometry method, and freeing it at the end of the
operation? Although how would you allow returned Geometrys to be
allocated outside of this pool... But maybe that doesn't matter - you
can just free the pool at the end of the PostGIS function.
This seems like it might be building GEOS to be a bit too specific to
its use in PostGIS, however. I think there's lots of people who want to
use it in other environments.
Is GEOS really that far from being memory-tight?
> ATB,
> Mark.
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geos-devel
Martin Davis
Senior Technical Architect
Refractions Research, Inc.
(250) 383-3022
