[geos-devel] An Immodest Proposal
Charlie Savage
cfis at savagexi.com
Tue Sep 30 00:30:53 EDT 2008
Paul,
> It turns out it is a quite small modification, and works pretty well:
> http://trac.osgeo.org/geos/attachment/ticket/208/memdiff.patch
> My patch adds the ability to override, and also has some printfs to
> show what is happening. When the overridden allocator is called
> without the runtime callback set, it prints "std alloc" and when it's
> called with the callback set, it prints "geos alloc".
If you're going to run into any problems it will be on Windows, since
its so fussy about memory being allocated/deallocated from the same
runtime library's heap. Looks like your solution does that. But I
wonder if there will be issues accessing the postgresql allocated memory
from GEOS - like what happens if you call sizeof and such? My guess it
works, but would be good to run a debug build of geos/postgis - built
with VC++2005 or 2008 since it adds various assertions to check these
sorts of things.
Charlie
Type: application/x-pkcs7-signature
Desc: S/MIME Cryptographic Signature
Url : http://lists.osgeo.org/pipermail/geos-devel/attachments/20080929/d21aceeb/smime-0001.bin
