[geos-devel] An Immodest Proposal
Chris Hodgson chodgson at refractions.net
Tue Sep 30 20:38:15 EDT 2008
Do all of the "new std:vector<Geometry *>" calls use the overridden new?
If not, then I think the problem is that the code inside the extern C{}
doesn't understand that we have overridden new and delete. It MIGHT be
as easy (and clumsy) as adding two methods geosNew and geosDelete,
outside of the extern C {} block (which in turn call the overridden new
and delete), and calling those from within the extern C{} instead of
calling the raw new/delete which we are overridden.
I would try this myself except I don't have the development environment
setup yet...
Chris
Paul Ramsey wrote:
> Help!
> I've attached the modified geos_c.cpp and geos_c.h.in files for geos
> for your perusal. The symptom is this:
> - Modified containsPrepared to use initGEOSMemory
> - Run an ST_Contains(g,g,i) prepared example
> - Memory is both allocated and deallocated through the over-ridden
> functions just fine
> - UNTIL
> - The code gets to the point where it has to deallocate a prepared
> geometry and runs GEOSPreparedGeom_destroy()
> - At that point, the deallocation does *not* enter the over-ridden
> new/delete operators, it appears to use default operators, and
> everything goes boom
> So,
> - the over-ride of new/delete seems to work fine inside the main geos
> library, things get both allocated and freed using palloc and pfree
> - but the delete inside the "extern C {}" block where
> GEOSPreparedGeom_destroy does *not* appear to be over-ridden by our
> cunning trick
> Anyone have the secret sauce?
> P.
