[geos-devel] [GEOS] #247: Can not compile GEOS SVN
    geos-trac at osgeo.org
    Fri Apr 10 07:43:58 EDT 2009
 Reporter:  robe        |       Owner:  geos-devel at lists.osgeo.org
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  3.1.1
Component:  Default     |     Version:  svn-trunk
 Severity:  Unassigned  |    Keywords:
 Maybe I'm missing something -- but just tried pulling SVN of GEOS.
 First I tried make clean and got a bunch of errors about aclocal 1.10
 missing or something.
 Then I tried
 doing an
 sh autogen.sh
 I can't autogen or compile it on either my OpenSUSE 10.3 box or Windows XP
 under MingW. both give similar Error.
 OpenSUSE gives this error
 sh autogen.sh
 * Running /usr/bin/libtoolize (1.5.24)
 \tOPTIONS = --force --copy
 * Running /usr/bin/aclocal (1.10)
 * Running /usr/bin/autoheader (2.61)
 * Running /usr/bin/automake (1.10)
 \tOPTIONS = --add-missing --copy
 configure.in:250: required file `tests/unit/tut/Makefile.in' not found
   Something went wrong, giving up!
 --Windows XP gives this error
 * Running /bin/libtoolize (1.4e)
 * Running /bin/aclocal (1.8.2)
 /usr/share/aclocal/autoopts.m4:22: warning: underquoted definition of
 AG_PATH_AUTOOPTS
   run info '(automake)Extending aclocal'
   or see
 http://sources.redhat.com/automake/automake.html#Extending%20aclocal
 * Running /bin/autoheader (2.59)
 * Running /bin/automake (1.8.2)
 configure.in:350: required file `tests/unit/tut/Makefile.in' not found
Ticket URL: <http://trac.osgeo.org/geos/ticket/247>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
