[geos-devel] split self-intersecting LineString into
non-intersecting lines
Quentin VUILLIOT
q.vuilliot at gmail.com
Thu Apr 23 04:24:45 EDT 2009
Hi Sanak!
Thank you so much for this trick, it is a bit curious but works just great!
Best regards,
Quentin
2009/4/22 Sanak <geosanak at gmail.com>:
> Hi Quentin,
> "Union" method will split self-intersection linestring.
> [Input]
> A:LINESTRING(0 0, 100 100, 0 100, 100 0)
> B:POINT(0 0)
> - B is a one node of A.
> Result = A.Union(B)
> [Output]
> Result:MULTILINESTRING ((0 0, 50 50), (50 50, 100 100, 0 100, 50 50), (50
> 50, 100 0))
> Refer to the document "FOSS4G 2007 : Secrets of the JTS Topology Suite"
> (http://www.foss4g2007.org/presentations/view.php?abstract_id=115 )
> for details.
> Regards,
> Sanak.
> 2009/4/21 Quentin VUILLIOT <q.vuilliot at gmail.com>
>> Hello everyone,
>> I'm not sure this is the right place to post such a question, but I
>> can't find any other Geos mailing-list or forum. So please excuse me
>> if I'm wrong here.
>> I can't find a way of splitting a linestring that intersects itself
>> into several linestrings that don't. I'm surprised not to find any
>> clues about that on the web, though it seems to me that it should be a
>> rather common problem, isn't it?
>> I mean, there is a function to determine whether a linestring is
>> simple or not, but nothing to do more with it, like locate the
>> intersection points?
>> Thank you in advance for your answers
>> Quentin
>> geos-devel mailing list
>> geos-devel at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geos-devel
