[geos-devel] [GEOS] #250: geos_contains(multipolygon,
polygon) returns false when it should return true
geos-trac at osgeo.org
Wed Apr 29 18:49:26 EDT 2009
#250: geos_contains(multipolygon, polygon) returns false when it should return
true
Reporter: cdestigter | Owner: geos-devel at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 3.1.1
Component: Default | Version: 3.0.0
Severity: Unassigned | Keywords:
In geodjango:
#!python
from django.contrib.gis import geos
g1 = geos.GEOSGeometry('MULTIPOLYGON(((0 0,0 10,10 10,10 0,0 0)))')
g2 = geos.GEOSGeometry('POLYGON((1 1,1 2,2 2,2 1,1 1))')
g1.contains(g2)
=> False
g2.within(g1)
=> False
Both of the above should return True. The following combinations work fine
though:
polygon.contains(polygon)
multipolygon.contains(multipolygon)
It's possible this has been fixed in a more recent version, though I
couldn't find any existing tickets on it. Feel free to close if that's the
case, stating when it was fixed.
Ticket URL: <http://trac.osgeo.org/geos/ticket/250>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
