[geos-devel] Porting LengthIndexedLine.project?
David Turner
novalis at novalis.org
Fri Aug 7 16:45:57 EDT 2009
OK, I've done the port. A patch, with ported tests, is attached.
On Thu, 2009-07-23 at 11:13 -0400, David Turner wrote:
> JTS has a class called LengthIndexedLine with a method "project", which
> lets you figure out the nearest point on a line to a given point. This
> is useful, for instance, if you are trying to figure out what street a
> person is on from (possibly slightly inaccurate) GPS observations.
> http://tsusiatsoftware.net/jts/javadoc/com/vividsolutions/jts/linearref/LengthIndexedLine.html#project(com.vividsolutions.jts.geom.Coordinate)
> PostGIS calls this function st_line_locate_point.
> GEOS doesn't seem to have it, even though I was under the impression
> that GEOS was merely a port of JTS. If I port JTS's project function
> and related functions such as extractPoint to GEOS, would that patch be
> likely to be accepted? Or am I missing something about the relationship
> between JTS and GEOS?
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geos-devel
Type: text/x-patch
Desc: not available
Url : http://lists.osgeo.org/pipermail/geos-devel/attachments/20090807/99834d9d/linearref-0001.bin
