[geos-devel] Missing files in geos-3.1.1.tar.bz2
Obe, Regina robe.dnd at cityofboston.gov
Tue Dec 8 08:50:25 EST 2009
Paul,
Geos 3.1.1 had missing files for VS.  I believe if you pull from SVN you get all the missing files.
On another note.  GEOS 3.2 is coming out really soon -- its up to RC3 and Mateusz has been working really hard to make sure all the pieces are packaged in there to compile from the tar ball without having to go to SVN.  I encourage you to give GEOS 3.2 a try.  I've found it to be a much stabler product than the 3.1 series in many ways (like dealing with topological exceptions not to mention improved speed)
Hope that helps,
Regina
From: geos-devel-bounces at lists.osgeo.org [mailto:geos-devel-bounces at lists.osgeo.org] On Behalf Of Paul Meems
Sent: Tuesday, December 08, 2009 4:55 AM
To: geos-devel at lists.osgeo.org
Subject: [geos-devel] Missing files in geos-3.1.1.tar.bz2
Hi List,
I'm new to this list.
I'm Paul Meems from The Netherlands.
I'm a member of the MapWindow GIS community.
We use GEOS together with GDAL in MapWindow GIS.
We're currently in the process of updating all our supporting libraries to the latest stable ones.
Yesterday I've downloaded 2009/06/15 geos-3.1.1.tar.bz2 and try to compile it using VS2008
I get all kinds of errors about missing files.
I managed to find some in SVN but these are still missing:
Error    104    fatal error C1083: Cannot open source file: '..\..\..\source\geom\util\
PolygonExtracter.cpp': No such file or directory    c1xx    geos_lib
Error    105    fatal error C1083: Cannot open source file: '..\..\..\source\geom\util\PointExtracter.cpp': No such file or directory    c1xx    geos_lib
Error    106    fatal error C1083: Cannot open source file: '..\..\..\source\geom\util\LinearComponentExtracter.cpp': No such file or directory    c1xx    geos_lib
Error    122    fatal error C1083: Cannot open source file: '..\..\..\source\geom\CoordinateSequenceFactory.cpp': No such file or directory    c1xx    geos_lib
I tried searching the net for this or on the GEOS website but I can't find a solution.
I did read something about not mixing source files of different version of GEOS.
So I'm puzzled how to continue.
I hope someone can help me.
Thanks,
Paul
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
URL: http://lists.osgeo.org/pipermail/geos-devel/attachments/20091208/6183f272/attachment.html
