[geos-devel] 3.1 vs 3.2
Paul Ramsey
pramsey at opengeo.org
Tue Dec 8 17:12:38 EST 2009
Not sure what this means, but:
---- 3.1 ----
Heron-2:xmltester pramsey$ time make check
make check-TESTS
Area of difference between obtained and expected: 0 - Tolerated diff: 0.449 (SUCCESS!)
Area of difference between obtained and expected: 0 - Tolerated diff: 0.605 (SUCCESS!)
bufferOriginalPrecision failed (TopologyException: depth mismatch at 378588 5.68601e+06), trying with reduced precision
recomputing with precision scale factor = 1e+08
Scaler: offsetX,Y: 0,0 scaleFactor: 1e+08
ReScaler: offsetX,Y: 0,0 scaleFactor: 1e+08
recomputing with precision scale factor = 1e+07
Scaler: offsetX,Y: 0,0 scaleFactor: 1e+07
ReScaler: offsetX,Y: 0,0 scaleFactor: 1e+07
Area of difference between obtained and expected: 4.98287e-05 - Tolerated diff: 495.66 (SUCCESS!)
Area of difference between obtained and expected: 0 - Tolerated diff: 6.68967 (SUCCESS!)
Area of difference between obtained and expected: 8.18545e-12 - Tolerated diff: 3.14191 (SUCCESS!)
Area of difference between obtained and expected: 0 - Tolerated diff: 703.749 (SUCCESS!)
Area of difference between obtained and expected: 0 - Tolerated diff: 17645.6 (SUCCESS!)
Area of difference between obtained and expected: 0 - Tolerated diff: 15299.8 (SUCCESS!)
Files: 20
Tests: 2216
Failed: 0
Succeeded: 2216
PASS: testrunner
1 test passed
real 0m29.194s
user 0m24.750s
sys 0m1.489s
---- 3.2 ----
make check-TESTS
bufferOriginalPrecision failed (TopologyException: assigned depths do not match 1.33558e+06 631781), trying with reduced precision
recomputing with precision scale factor = 1e+10
Scaler: offsetX,Y: 0,0 scaleFactor: 1e+10
ReScaler: offsetX,Y: 0,0 scaleFactor: 1e+10
recomputing with precision scale factor = 1e+09
Scaler: offsetX,Y: 0,0 scaleFactor: 1e+09
ReScaler: offsetX,Y: 0,0 scaleFactor: 1e+09
bufferOriginalPrecision failed (TopologyException: assigned depths do not match 1.33559e+06 631780), trying with reduced precision
Files: 58
Tests: 3582
Failed: 0
Succeeded: 3582
PASS: testrunner
All 1 tests passed
real 0m11.558s
user 0m10.630s
sys 0m0.230s
