[geos-devel] 3.2.0 Final
strk strk at keybit.net
Sat Dec 12 03:34:54 EST 2009
On Fri, Dec 11, 2009 at 08:22:31PM +0100, Barend Gehrels wrote:
> Leaks? The C Api just wraps it...
The C Api wraps a small portion of the C++ API.
The thing is that in C++ there are *a lot* of interfaces
exposed which should not be.
You might have noticed that many of the headers were not
installed up to 3.1.x. This was an attempt to reduce the
set of exposed interface.
Remember that GEOS is a direct port of JTS, where (in Java)
there are visibility levels that are not supported in C++
(default visibility == only classes in same package can use
those interfaces). In GEOS those all became public instead.
--strk;
 Free GIS & Flash consultant/developer      ()  ASCII Ribbon Campaign
 http://foo.keybit.net/~strk/services.html  /\  Keep it simple!
