[geos-devel] 3.2.0 release ready for download
strk strk at keybit.net
Tue Dec 15 03:49:36 EST 2009
On Mon, Dec 14, 2009 at 06:39:21PM -0500, Greg Troxel wrote:
> The shlib major version changed; probably NEWS should mention that.
GEOS has 2 shared libraries.
The one implementing the C++ API and the one implementing the C API.
While we maintain proper library versioning for the C API, we don't
for the C++ one, due to the way too wide set of exposed interfaces
we should look at to figure when ABI was or wasn't broken (and in C++
land ABI breaks SO easily).
> Are
> there incompatible ABI changes?
For the C++ shlib, most likely.
> (From a packaging point of view, shlib
> version changes when there aren't actually ABI changes generates work
> that could be avoided; all depending packages need a version change
> because they only interoperate with one or the other geos version.)
This is exactly the reason why we incourage use of the C library
(libgeos_c.so). The C library hard continues to expose a compatible ABI
to the ABI-incompatible C++ library.
So, while GEOS 3.2.0 *c++* lib is a few steps away from GEOS 3.0.0 *c++* lib,
any code which linked against the *c* lib in GEOS 3.0.0 will still work
with the *c* lib of GEOS 3.2.0.
>From a packaging point of view you should likely properly encode
if a client is dependent on *libgeos* or *libgeos_c* as that makes
a big difference.
Is this too much confusing ?
--strk;
 Free GIS & Flash consultant/developer      ()  ASCII Ribbon Campaign
 http://foo.keybit.net/~strk/services.html  /\  Keep it simple!
