[geos-devel] [GEOS] #230: polygon intersection exception.
Mateusz Loskot
mateusz at loskot.net
Wed Feb 25 18:16:17 EST 2009
Martin,
Thanks for investigating. I've closed the ticket.
Martin Davis wrote:
> The second polygon is invalid - this is expected behaviour.
>> Reporter: anigold | Owner: geos-devel at lists.osgeo.org
>> Type: defect | Status: new
>> Priority: major | Milestone: 3.1.0
>> Component: Default | Version: 3.0.0
>> Severity: Unassigned | Keywords:
>> std::string str = "POLYGON ((112.3903710739794900
>> 22.3851129617344210, 114.1261324827294900 22.3851129617344210,
>> 114.1261324827294900 23.5479374992368590, 112.3903710739794900
>> 23.5479374992368590, 112.3903710739794900 22.3851129617344210)) ";
>> geos::geom::Geometry* pgeom0 = reader.read( str );
>> str = "POLYGON ((114.0876590000000000 22.5249449999999990,
>> 114.1853440000000000 22.5531790000000000, 114.1704040000000000
>> 22.5438380000000010, 114.1423630000000000 22.5351350000000000,
>> 114.0874290000000000 22.5245199999999990, 114.0892680000000000
>> 22.5255820000000000, 114.0936350000000100 22.5266430000000000,
>> 114.0876590000000000 22.5249449999999990))";
>> geos::geom::Geometry* pgeom1 = reader.read( str );
>> geos::geom::Geometry* pint = pgeom0->intersection( pgeom1 );
>> when execute the last line code, the util::TopologyException will be
>> throwed.
>> geos-devel mailing list
>> http://lists.osgeo.org/mailman/listinfo/geos-devel
Mateusz Loskot, http://mateusz.loskot.net
Charter Member of OSGeo, http://osgeo.org
