[geos-devel] [GEOS] #232: Static string in WKBReader causes glibc errors when Geos is statically linked
GEOS geos-trac at osgeo.org
Thu Feb 26 09:36:16 EST 2009
linked
 Reporter:  yvesdaemen  |       Owner:  geos-devel at lists.osgeo.org
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  3.1.0
Component:  Default     |     Version:  3.0.3
 Severity:  Unassigned  |    Keywords:
 I am statically linking Geos against my own C program. This program runs
 without problems, except until the very end when a glibc errors occurs.
 I have traced this back to the static string BAD_GEOM_TYPE_MSG. When I
 remove the static modifier and initialise the string inside the
 constructor, everything goes well.
 I did not get this error when linking dynamically, but Valgrind complained
 about an invalid free. This is probably the same thing, only my program
 did not crash on it.
Ticket URL: <http://trac.osgeo.org/geos/ticket/232>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
