[geos-devel] Segmentation Fault in ARM platform
Adriano C Naspolini adriano at arvus.com.br
Sat Feb 28 15:45:07 EST 2009
Hi people,
I recently installed gdal-1.6.0+geos-3.0.3 in my pc as in my target
prataform (an ARM). Initially, i had an endianess problem with gdal (the
target arm is little endian in bytes but big endian in words, so 0x1234
becomes 0x3412 and 0x12345678 becomes 0x56781234). After patching
shapelib it's working.
The problem now is with geos: a segmentation fault when I use Contains()
function (also with Crosses(), there are certainly others). I think this
could be the same endianness problem, or something like it, because the
program runs normally on my pc.
Backtrace from GDB:
#0  0x2c327dfc in memcpy () from /lib/libc.so.6
#1  0x2c204d7c in std::basic_streambuf<char, std::char_traits<char>
 >::xsgetn () from /usr/lib/libstdc++.so.5
#2  0x2c43e580 in std::istream::read () from /usr/lib/libstdc++.so.6
#3  0x2abb58a4 in geos::io::WKBReader::readGeometry (this=0x7f5ff8a0) at
../../source/headers/geos/io/ByteOrderDataInStream.inl:58
#4  0x2aad8ed8 in GEOSGeomFromWKB_buf (wkb=0x247f28 "\001\003", size=93)
at geos_c.cpp:598
#5  0x2b148d4c in OGRGeometry::exportToGEOS (this=0x263fa0) at
ogrgeometry.cpp:1706
#6  0x2b148614 in OGRGeometry::Contains (this=0x7f5ff8b0,
poOtherGeom=0x0) at ogrgeometry.cpp:2560
#7  0x0001ee8c in Mapa::getAttr (this=0xac818,
longitude=-47.590694333333332, latitude=-15.337605333333332) at
src/model/mapa.cpp:191
Any Idea?
Thank you.
Adriano
