[geos-devel] Segmentation Fault in ARM platform
Sat Feb 28 17:39:01 EST 2009
Paul Ramsey wrote:
> You're going to want to find someone who can re-produce this, which
> means someone with a big-endian platform. Perhaps Frank can on his old
> iBook. Note that you are transferring WKB from OGR to GEOS, so the
> problem could be the writing step in OGR (writing something invalid)
> or the reading step in GEOS (screwing up). Attach your program to an
> issue in trac.
Paul,
As I understand it the ARM is being used in "middle endian"
mode, or at least is not a traditional big endian system so I
don't believe my iBook will produce the same problem.
I'm personally not too keen on making all my software support this
... distinct ... endian case.  I'm fairly confident that Adriano is
only seeing the tip of the iceberg so far.
Best regards,
> On Sat, Feb 28, 2009 at 12:45 PM, Adriano C Naspolini
> <adriano at arvus.com.br> wrote:
>> Hi people,
>> I recently installed gdal-1.6.0+geos-3.0.3 in my pc as in my target
>> prataform (an ARM). Initially, i had an endianess problem with gdal (the
>> target arm is little endian in bytes but big endian in words, so 0x1234
>> becomes 0x3412 and 0x12345678 becomes 0x56781234). After patching shapelib
>> it's working.
>> The problem now is with geos: a segmentation fault when I use Contains()
>> function (also with Crosses(), there are certainly others). I think this
>> could be the same endianness problem, or something like it, because the
>> program runs normally on my pc.
>> Backtrace from GDB:
>> #0  0x2c327dfc in memcpy () from /lib/libc.so.6
>> #1  0x2c204d7c in std::basic_streambuf<char, std::char_traits<char>
>>> ::xsgetn () from /usr/lib/libstdc++.so.5
>> #2  0x2c43e580 in std::istream::read () from /usr/lib/libstdc++.so.6
>> #3  0x2abb58a4 in geos::io::WKBReader::readGeometry (this=0x7f5ff8a0) at
>> ../../source/headers/geos/io/ByteOrderDataInStream.inl:58
>> #4  0x2aad8ed8 in GEOSGeomFromWKB_buf (wkb=0x247f28 "\001\003", size=93) at
>> geos_c.cpp:598
>> #5  0x2b148d4c in OGRGeometry::exportToGEOS (this=0x263fa0) at
>> ogrgeometry.cpp:1706
>> #6  0x2b148614 in OGRGeometry::Contains (this=0x7f5ff8b0, poOtherGeom=0x0)
>> at ogrgeometry.cpp:2560
>> #7  0x0001ee8c in Mapa::getAttr (this=0xac818,
>> longitude=-47.590694333333332, latitude=-15.337605333333332) at
>> src/model/mapa.cpp:191
>> Any Idea?
>> Thank you.
>> Adriano
>> geos-devel mailing list
>> geos-devel at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geos-devel
