[geos-devel] Re: Thread Safe CAPI 2.0 patch online
Chuck Thibert
charles.thibert at ingres.com
Tue Jan 6 14:01:30 EST 2009
Hi again,
With the holidays over, just want to push this up the stack again. I
want to be sure it's commit ready when I hand it off. Any further
comments?
Thanks,
Chuck
On Fri, 2008-12-19 at 15:42 -0500, Chuck Thibert wrote:
> Hi all,
> I've changed the patch based on Paul's comments.
> -- combined the two header files for easy maintenance. (This 'fixed' the
> configure error by getting rid of the thread safe header.)
> -- fixed the char * error.
> -- changed the .c from geosTS_c.cpp to geos_ts_c.cpp
> -- moved the test executables to tests/unit/capi directory. This seemed
> to cause patch a bit of problems so I created a little script that does
> the svn move before applying the patch.
> All this is in a new 2.0 tar file attached to the ticket.
> Thanks again for the testing and comments Paul.
> Chuck
