[geos-devel] C API coordinate sequence dimensions
Sean Gillies
sgillies at frii.com
Mon Jan 12 14:37:15 EST 2009
Thanks, Regina, that hints that the supporting GEOS C API functions
might be considering z, but then again, the 3D might be implemented in
the PostGIS lib.
On Jan 12, 2009, at 12:18 PM, Obe, Regina wrote:
> A lot of these are catalogued here
> http://postgis.refractions.net/documentation/manual-svn/ch08.html#id2671967
> and
> ST_Union and I just discovered even ST_BuildArea.
> ST_ConvexHull (but that in my opinion gives goofy results).
> Though still debating how to describe that their results are
> debateable.
> Also ST_BuildArea seems to hmm do a 2D and then tack on the Z so I
> guess I should add that to the list. Simon tested this out when he
> was doing this write up and to my shock it sort of preserved 3D
> though I would say incorrectly. Any rate I don't think he has that
> here, but still an interesting read
> http://www.spatialdbadvisor.com/postgis_tips_tricks
> -----Original Message-----
> From: geos-devel-bounces at lists.osgeo.org on behalf of Sean Gillies
> Sent: Mon 1/12/2009 2:00 PM
> To: GEOS Development List
> Subject: Re: [geos-devel] C API coordinate sequence dimensions
> Ah, I didn't know this. Which ones?
> On Jan 12, 2009, at 11:40 AM, Paul Ramsey wrote:
> > Not all operations are 2D, just 99% of them. Some of the overlay ops
> > try to compute "correct" derived Z-values.
> > P
> > On Jan 12, 2009, at 10:04 AM, Sean Gillies wrote:
> >> So, the dimension argument in GEOSCoordSeq_create is ignored unless
> >> the active sequence implementation takes dimensions other than 3?
> >> Why is GEOS's default sequence 3D when all operations are 2D?
> >> Sean
> >> On Jan 12, 2009, at 10:56 AM, Martin Davis wrote:
> >>> Actually JTS implements this correctly. The return value from
> >>> getDimension is computed by the implementation of
> >>> CoordinateSequence. In the case of DefaultCoordinateSequence
> >>> (which by the way is deprecated and replaced by
> >>> CoordinateArraySequence) the value is alway 3, since the
> >>> Coordinate representation used by these sequences always allows
> >>> for 3 ordinates.
> >>> In the case of PackedCoordinateSequence the dimension can be
> >>> selected on creation, and this is the value that is returned by
> >>> getDimension.
> >>> Sanak wrote:
> >>>> Hi list,
> >>>> I don't know that this is a known bug, but
> >>>> CoordinateArraySequence.getDimension() method always return 3.
> >>>> [trunk/source/headers/geos/geom/CoordinateArraySequence.h - line
> >>>> 88]
> >>>> size_t getDimension() const { return 3; }
> >>>> JTS(JTS Topology Suite) seems to be also the same.
> >>>> [jts/src/com/vividsolutions/jts/geom/
> >>>> DefaultCoordinateSequence.java - line 95]
> >>>> public int getDimension() { return 3; }
> >>>> I don't know that this is a specification or not...
> >>>> Regards,
> >>>> Sanak.
> >>>> 2009/1/12 Sean Gillies <sgillies at frii.com
> >>>> <mailto:sgillies at frii.com>>
> >>>> I'm finding that GEOSCoordSeq_getDimensions returns 3 no matter
> >>>> what
> >>>> # Accessing libgeos_c via Python ctypes
> >>>> >>> s = lgeos.GEOSCoordSeq_create(2, 2)
> >>>> >>> ndim = c_int()
> >>>> >>> lgeos.GEOSCoordSeq_getDimensions(s, byref(ndim))
> >>>> 1
> >>>> >>> ndim
> >>>> c_long(3)
> >>>> Is this a known bug? Looks like we're only testing creation of
> 3D
> >>>> coordinate sequences in
> >>>> http://trac.osgeo.org/geos/browser/trunk/tests/unit/capi/GEOSCoordSeqTest.cpp
> >>>> Sean Gillies
> >>>> http://sgillies.net
> >>>> _______________________________________________
> >>>> geos-devel mailing list
> >>>> geos-devel at lists.osgeo.org <mailto:geos-devel at lists.osgeo.org>
> >>>> http://lists.osgeo.org/mailman/listinfo/geos-devel
> >>> Martin Davis
> >>> Senior Technical Architect
> >>> Refractions Research, Inc.
> >>> (250) 383-3022
> >> Sean Gillies
> >> sean.gillies at gmail.com
> >> http://sgillies.net
> > Paul Ramsey
> > pramsey at cleverelephant.ca
> > +1 250 885 0632
> The substance of this message, including any attachments, may be
> confidential, legally privileged and/or exempt from disclosure
> pursuant to Massachusetts law. It is intended solely for the
> addressee. If you received this in error, please contact the sender
> and delete the material from any computer.
> Help make the earth a greener place. If at all possible resist
> printing this email and join us in saving paper.
