[geos-devel] RE: Can't compile Geos 3.1 under OpenSUSE anymore
Obe, Regina robe.dnd at cityofboston.gov
Tue Jan 13 09:42:32 EST 2009
Oops sent to wrong dev group last time.
-----Original Message-----
Sent: Tuesday, January 13, 2009 9:40 AM
To: 'PostGIS Development Discussion'
Subject: Can't compile Geos 3.1 under OpenSUSE anymore
I assume this is because of the recent changes.  I did an svn up and a
reconfigure and then compile under OpenSUSE.
I get this error
 g++ -DHAVE_CONFIG_H -I. -I../source/headers -I../source/headers/geos
-I../source/headers -DGEOS_CAPI_VERSION=\"3.1.0-CAPI-1.5.0\"
-DGEOS_JTS_PORT=\"1.7.1\" -g -O2 -DGEOS_INLINE -Wall -ansi -pedantic
-Wno-long-long -MT libgeos_c_la-geos_c.lo -MD -MP -MF
.deps/libgeos_c_la-geos_c.Tpo -c geos_c.cpp -o libgeos_c_la-geos_c.o
>/dev/null 2>&1
mv -f .deps/libgeos_c_la-geos_c.Tpo .deps/libgeos_c_la-geos_c.Plo
make[1]: *** No rule to make target `geos_ts_c.cpp', needed by
`libgeos_c_la-geos_ts_c.lo'.  Stop.
make[1]: Leaving directory `/projects/geos-3.1.0SVN/capi'
make: *** [all-recursive] Error 1
Am I missing something?
Thanks,
Regina
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
