[geos-devel] RE: [postgis-devel] Can't compile Geos 3.1
underOpenSUSE anymore
Obe, Regina
robe.dnd at cityofboston.gov
Tue Jan 13 10:54:01 EST 2009
Okay that fixed my OpenSUSE compile problem.
On MingW, getting a different error now -- but haven't done a complete
clean blowout so it could be remnants of something else. But just in
case. Below is what I get under MingW
-DDLL_EXPORT -DPIC -o .libs/libgeos_c_la-geos_ts_c.o
geos_ts_c.cpp: In function `char*
GEOSisValidReason_r(GEOSContextHandle_HS*, const
geos::geom::Geometry*)':
geos_ts_c.cpp:587: error: `strdup' was not declared in this scope
geos_ts_c.cpp:587: warning: unused variable 'strdup'
GEOSWKBWriter_getIncludeSRID_r(GEOSContextHandle_HS*, const
GEOSWKBWriter*)':
geos_ts_c.cpp:3682: warning: converting to non-pointer type `char' from
NULL
geos_ts_c.cpp:3688: warning: converting to non-pointer type `char' from
NULL
geos_ts_c.cpp:3699: warning: converting to non-pointer type `char' from
NULL
make[1]: *** [libgeos_c_la-geos_ts_c.lo] Error 1
make[1]: Leaving directory `/D/SVNProjects/geos/trunk/capi'
make: *** [all-recursive] Error 1
I'll be testing under Visual Studio in the next day or so.
-----Original Message-----
[mailto:geos-devel-bounces at lists.osgeo.org] On Behalf Of Paul Ramsey
Sent: Tuesday, January 13, 2009 10:49 AM
To: GEOS Development List
Subject: Re: [geos-devel] RE: [postgis-devel] Can't compile Geos 3.1
Yep, same here on a fresh checkout. And there was indeed a file
missing from my check-in. Fixed at r2233.
P.
On Tue, Jan 13, 2009 at 7:02 AM, Obe, Regina <robe.dnd at cityofboston.gov>
wrote:
> Mark,
> Good thought. I can't remember if I did an autogen or not, but just
did
> and my OpenSUSE is still compiling.
> My MingW install which I did do an sh autogen.sh , configure, make
> clean, make is failing with the same error
> g++ -DHAVE_CONFIG_H -I. -I. -I../source/headers
> -I../source/headers/geos -I../source/headers
> -DGEOS_CAPI_VERSION=\"3.1.0-CAPI-1.5.0\" -DGEOS_JTS_PORT=\"1.7.1\" -g
> -O2 -DGEOS_INLINE -Wall -ansi -pedantic -Wno-long-long -MT
> libgeos_c_la-geos_c.lo -MD -MP -MF .deps/libgeos_c_la-geos_c.Tpo -c
> geos_c.cpp -DDLL_EXPORT -DPIC -o .libs/libgeos_c_la-geos_c.o
> geos_c.cpp -o libgeos_c_la-geos_c.o >/dev/null 2>&1
> make[1]: *** No rule to make target `geos_ts_c.cpp', needed by
> `libgeos_c_la-geos_ts_c.lo'. Stop.
> Have you tried the latest one?
> My next step is to blow out my geos source and start from scratch.
> Thanks,
> Regina
> From: postgis-devel-bounces at postgis.refractions.net
> [mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of
Mark
> Cave-Ayland
> Sent: Tuesday, January 13, 2009 9:45 AM
> To: PostGIS Development Discussion
> Subject: Re: [postgis-devel] Can't compile Geos 3.1 under OpenSUSE
> anymore
> Obe, Regina wrote:
>> I assume this is because of the recent changes. I did an svn up and
a
>> reconfigure and then compile under OpenSUSE.
>> I get this error
>> g++ -DHAVE_CONFIG_H -I. -I../source/headers -I../source/headers/geos
>> -I../source/headers -DGEOS_CAPI_VERSION=\"3.1.0-CAPI-1.5.0\"
>> -DGEOS_JTS_PORT=\"1.7.1\" -g -O2 -DGEOS_INLINE -Wall -ansi -pedantic
>> -Wno-long-long -MT libgeos_c_la-geos_c.lo -MD -MP -MF
>> .deps/libgeos_c_la-geos_c.Tpo -c geos_c.cpp -o libgeos_c_la-geos_c.o
>>> /dev/null 2>&1
>> mv -f .deps/libgeos_c_la-geos_c.Tpo .deps/libgeos_c_la-geos_c.Plo
>> make[1]: Leaving directory `/projects/geos-3.1.0SVN/capi'
>> Am I missing something?
>> Thanks,
>> Regina
> Hmmm the "ts" part implies this is something to do with the
thread-safe
> API patch. Perhaps you need to re-run autogen.sh so that it picks up
the
> new files? Failing that does a brand new checkout work?
> HTH,
> Mark.
> Mark Cave-Ayland
> Sirius Corporation - The Open Source Experts
> http://www.siriusit.co.uk
> T: +44 870 608 0063
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
> The substance of this message, including any attachments, may be
> confidential, legally privileged and/or exempt from disclosure
> pursuant to Massachusetts law. It is intended
> solely for the addressee. If you received this in error, please
> contact the sender and delete the material from any computer.
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geos-devel
