3D operations (Re: [geos-devel] C API coordinate
sequencedimensions)
Obe, Regina
robe.dnd at cityofboston.gov
Wed Jan 14 08:17:07 EST 2009
Well from my observation it looks like most of those Ops functions (not
sure about Union and Intersection) -- first do a 2D operation and then
do some sort of apply the Z back on. So the Z is never considered in
the basic operation -- thus the cause of a lot of the goofiness.
Take this example. It seems clear to me that these polygon's are not
within each other so it should be a multipolygon not a Polygon with a
hole. One lies above the other.
SELECT ST_AsEWKT(ST_BuildArea('MULTILINESTRING((0 0 1,20 0 1,20 20 1,0
20 1,0 0 1),(10 10 2,10 11 2,11 11 2,11 10 2,10 10 2))'))
"POLYGON((0 0 1,0 20 1,20 20 1,20 0 1,0 0 1),(10 10 2,11 10 2,11 11 2,10
11 2,10 10 2))"
-----Original Message-----
[mailto:geos-devel-bounces at lists.osgeo.org] On Behalf Of strk
Sent: Wednesday, January 14, 2009 4:04 AM
To: GEOS Development List
Subject: Re: 3D operations (Re: [geos-devel] C API coordinate
sequencedimensions)
On Wed, Jan 14, 2009 at 07:54:21AM +0000, Mark Cave-Ayland wrote:
> Can anyone with more experience with BuildArea (like Martin!) comment
on
> whether this is a GEOS bug or simply a problem with behaviour > 2
> dimensions being undefined?
JTS didn't support 3d when I added it to GEOS, so can't really
serve as a source of information. The 3d task was added driven by
customer needs, so the only working and tested functions was the one
the customer needed. If I recall correctly it was mainly Intersection
and probably Union.
Since other functions are based on the former, there may be side-effects
you wouldn't care about if you aren't using 3d features.
Paul draw the specs about expected behaviour. Dunno if there's a doc
around and I likely lost mine (Oops).
--strk;
Free GIS & Flash consultant/developer () ASCII Ribbon Campaign
http://foo.keybit.net/~strk/services.html /\ Keep it simple!
geos-devel mailing list
geos-devel at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/geos-devel
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
