[geos-devel] RE: [postgis-devel] Can't compile Geos
3.1underOpenSUSE anymore, compiles okay under Vc2005 with changes
Paul Ramsey
pramsey at cleverelephant.ca
Wed Jan 14 11:55:37 EST 2009
Someone smarter than me is going to have to solve this. strdup is
defined in <cstring> if I'm not mistaken, and that's included at the
top of the file. So why is it not being picked up? You are even using
the gnu toolchain, so all the more reason you should have consistent
behavior to the linux/osx builds.
P.
On Wed, Jan 14, 2009 at 5:05 AM, Obe, Regina <robe.dnd at cityofboston.gov> wrote:
> Paul,
> Okay I blew out my geos trunk and it didn't help. Though your change to
> config forced me to finally bite the bullet and upgrade my mingw
> autoconf and automake since I could no longer even sh autogen.sh after
> that and even copying my configure from my OpenSUSE install did not
> work. I was meaning to upgrade since PostGIS requires a newer autoconf
> too.
> I guess your other changes got rid of some of the warnings and I am left
> with
> geos_ts_c.cpp: In function `char*
> GEOSisValidReason_r(GEOSContextHandle_HS*, const
> geos::geom::Geometry*)':
> geos_ts_c.cpp:587: error: `strdup' was not declared in this scope
> geos_ts_c.cpp:587: warning: unused variable 'strdup'
> make[1]: *** [libgeos_c_la-geos_ts_c.lo] Error 1
> make[1]: Leaving directory `/D/SVNProjects/geos/trunk/capi'
> make: *** [all-recursive] Error 1
> I wonder if upgrading my GCC would help. I think I'm running GCC
> 3.4.5.
> On another note -- I think for VC 2005 the geos_ts_c.cpp has to be
> added. I just compiled under VC 2005 and that seemd to compile okay
> with 300 someodd warnings after adding that dependency.
> I'll send you a patch for that once I've cleaned it up. I wanted to get
> rid of that reference to c:/mys... that has been stuck in there for eons
> too.
> Thanks,
> Regina
> -----Original Message-----
> From: geos-devel-bounces at lists.osgeo.org
> [mailto:geos-devel-bounces at lists.osgeo.org] On Behalf Of Paul Ramsey
> Sent: Tuesday, January 13, 2009 11:06 AM
> To: GEOS Development List
> Subject: Re: [geos-devel] RE: [postgis-devel] Can't compile Geos
> Doesn't make much sense to me. <cstring> is #include'd, so...?
> On Tue, Jan 13, 2009 at 7:54 AM, Obe, Regina <robe.dnd at cityofboston.gov>
> wrote:
>> Okay that fixed my OpenSUSE compile problem.
>> On MingW, getting a different error now -- but haven't done a complete
>> clean blowout so it could be remnants of something else. But just in
>> case. Below is what I get under MingW
>> -DDLL_EXPORT -DPIC -o .libs/libgeos_c_la-geos_ts_c.o
>> GEOSWKBWriter_getIncludeSRID_r(GEOSContextHandle_HS*, const
>> GEOSWKBWriter*)':
>> geos_ts_c.cpp:3682: warning: converting to non-pointer type `char'
> from
>> NULL
>> geos_ts_c.cpp:3688: warning: converting to non-pointer type `char'
> from
>> NULL
>> geos_ts_c.cpp:3699: warning: converting to non-pointer type `char'
> from
>> NULL
>> I'll be testing under Visual Studio in the next day or so.
>> Sent: Tuesday, January 13, 2009 10:49 AM
>> Subject: Re: [geos-devel] RE: [postgis-devel] Can't compile Geos 3.1
>> Yep, same here on a fresh checkout. And there was indeed a file
>> missing from my check-in. Fixed at r2233.
>> P.
>> On Tue, Jan 13, 2009 at 7:02 AM, Obe, Regina
>> wrote:
>>> Mark,
>>> Good thought. I can't remember if I did an autogen or not, but just
>> did
>>> and my OpenSUSE is still compiling.
>>> My MingW install which I did do an sh autogen.sh , configure, make
>>> clean, make is failing with the same error
>>> g++ -DHAVE_CONFIG_H -I. -I. -I../source/headers
>>> -I../source/headers/geos -I../source/headers
>>> -DGEOS_CAPI_VERSION=\"3.1.0-CAPI-1.5.0\" -DGEOS_JTS_PORT=\"1.7.1\" -g
>>> -O2 -DGEOS_INLINE -Wall -ansi -pedantic -Wno-long-long -MT
>>> libgeos_c_la-geos_c.lo -MD -MP -MF .deps/libgeos_c_la-geos_c.Tpo -c
>>> geos_c.cpp -DDLL_EXPORT -DPIC -o .libs/libgeos_c_la-geos_c.o
>>> geos_c.cpp -o libgeos_c_la-geos_c.o >/dev/null 2>&1
>>> make[1]: *** No rule to make target `geos_ts_c.cpp', needed by
>>> `libgeos_c_la-geos_ts_c.lo'. Stop.
>>> Have you tried the latest one?
>>> My next step is to blow out my geos source and start from scratch.
>>> Thanks,
>>> Regina
>>> From: postgis-devel-bounces at postgis.refractions.net
>>> [mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of
>> Mark
>>> Cave-Ayland
>>> Sent: Tuesday, January 13, 2009 9:45 AM
>>> To: PostGIS Development Discussion
>>> Subject: Re: [postgis-devel] Can't compile Geos 3.1 under OpenSUSE
>>> anymore
>>> Obe, Regina wrote:
>>>> I assume this is because of the recent changes. I did an svn up and
>> a
>>>> reconfigure and then compile under OpenSUSE.
>>>> I get this error
>>>> g++ -DHAVE_CONFIG_H -I. -I../source/headers
>>>> -I../source/headers -DGEOS_CAPI_VERSION=\"3.1.0-CAPI-1.5.0\"
>>>> -DGEOS_JTS_PORT=\"1.7.1\" -g -O2 -DGEOS_INLINE -Wall -ansi -pedantic
>>>> -Wno-long-long -MT libgeos_c_la-geos_c.lo -MD -MP -MF
>>>> .deps/libgeos_c_la-geos_c.Tpo -c geos_c.cpp -o libgeos_c_la-geos_c.o
>>>>> /dev/null 2>&1
>>>> mv -f .deps/libgeos_c_la-geos_c.Tpo .deps/libgeos_c_la-geos_c.Plo
>>>> make[1]: Leaving directory `/projects/geos-3.1.0SVN/capi'
>>>> Am I missing something?
>>>> Thanks,
>>>> Regina
>>> Hmmm the "ts" part implies this is something to do with the
>> thread-safe
>>> API patch. Perhaps you need to re-run autogen.sh so that it picks up
>> the
>>> new files? Failing that does a brand new checkout work?
>>> HTH,
>>> Mark.
>>> Mark Cave-Ayland
>>> Sirius Corporation - The Open Source Experts
>>> http://www.siriusit.co.uk
>>> T: +44 870 608 0063
>>> postgis-devel mailing list
>>> postgis-devel at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
>>> The substance of this message, including any attachments, may be
>>> confidential, legally privileged and/or exempt from disclosure
>>> pursuant to Massachusetts law. It is intended
>>> solely for the addressee. If you received this in error, please
>>> contact the sender and delete the material from any computer.
>>> geos-devel mailing list
>>> geos-devel at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/geos-devel
