[geos-devel] RE: [postgis-devel] Can't
compileGeos3.1underOpenSUSE anymore,
compiles okay under Vc2005 with changes
Obe, Regina
robe.dnd at cityofboston.gov
Wed Jan 14 15:05:43 EST 2009
That seems to work.
-----Original Message-----
[mailto:geos-devel-bounces at lists.osgeo.org] On Behalf Of Paul Ramsey
Sent: Wednesday, January 14, 2009 12:43 PM
To: GEOS Development List
Subject: Re: [geos-devel] RE: [postgis-devel] Can't
compileGeos3.1underOpenSUSE anymore, compiles okay under Vc2005 with
changes
Does this help?
On Wed, Jan 14, 2009 at 9:27 AM, Obe, Regina <robe.dnd at cityofboston.gov>
wrote:
> Evidentally we had the same issue with CLocalizer and the use of
strdup
> was removed. Not sure if that is the right solution though.
> http://trac.osgeo.org/geos/changeset/2180
> From: geos-devel-bounces at lists.osgeo.org
> Sent: Wednesday, January 14, 2009 11:56 AM
> Subject: Re: [geos-devel] RE: [postgis-devel] Can't compile
> Geos3.1underOpenSUSE anymore, compiles okay under Vc2005 with changes
> Someone smarter than me is going to have to solve this. strdup is
> defined in <cstring> if I'm not mistaken, and that's included at the
> top of the file. So why is it not being picked up? You are even using
> the gnu toolchain, so all the more reason you should have consistent
> behavior to the linux/osx builds.
> P.
> On Wed, Jan 14, 2009 at 5:05 AM, Obe, Regina
> wrote:
>> Paul,
>> Okay I blew out my geos trunk and it didn't help. Though your change
> to
>> config forced me to finally bite the bullet and upgrade my mingw
>> autoconf and automake since I could no longer even sh autogen.sh
after
>> that and even copying my configure from my OpenSUSE install did not
>> work. I was meaning to upgrade since PostGIS requires a newer
> autoconf
>> too.
>> I guess your other changes got rid of some of the warnings and I am
> left
>> with
>> geos_ts_c.cpp: In function `char*
>> GEOSisValidReason_r(GEOSContextHandle_HS*, const
>> geos::geom::Geometry*)':
>> geos_ts_c.cpp:587: error: `strdup' was not declared in this scope
>> geos_ts_c.cpp:587: warning: unused variable 'strdup'
>> make[1]: *** [libgeos_c_la-geos_ts_c.lo] Error 1
>> make[1]: Leaving directory `/D/SVNProjects/geos/trunk/capi'
>> make: *** [all-recursive] Error 1
>> I wonder if upgrading my GCC would help. I think I'm running GCC
>> 3.4.5.
>> On another note -- I think for VC 2005 the geos_ts_c.cpp has to be
>> added. I just compiled under VC 2005 and that seemd to compile okay
>> with 300 someodd warnings after adding that dependency.
>> I'll send you a patch for that once I've cleaned it up. I wanted to
> get
>> rid of that reference to c:/mys... that has been stuck in there for
> eons
>> too.
>> Thanks,
>> Regina
>> Sent: Tuesday, January 13, 2009 11:06 AM
>> Subject: Re: [geos-devel] RE: [postgis-devel] Can't compile Geos
>> Doesn't make much sense to me. <cstring> is #include'd, so...?
>> On Tue, Jan 13, 2009 at 7:54 AM, Obe, Regina
>> wrote:
>>> Okay that fixed my OpenSUSE compile problem.
>>> On MingW, getting a different error now -- but haven't done a
> complete
>>> clean blowout so it could be remnants of something else. But just
in
>>> case. Below is what I get under MingW
>>> -DDLL_EXPORT -DPIC -o .libs/libgeos_c_la-geos_ts_c.o
>>> GEOSWKBWriter_getIncludeSRID_r(GEOSContextHandle_HS*, const
>>> GEOSWKBWriter*)':
>>> geos_ts_c.cpp:3682: warning: converting to non-pointer type `char'
>> from
>>> NULL
>>> geos_ts_c.cpp:3688: warning: converting to non-pointer type `char'
>> from
>>> NULL
>>> geos_ts_c.cpp:3699: warning: converting to non-pointer type `char'
>> from
>>> NULL
>>> I'll be testing under Visual Studio in the next day or so.
>>> Sent: Tuesday, January 13, 2009 10:49 AM
>>> Subject: Re: [geos-devel] RE: [postgis-devel] Can't compile Geos 3.1
>>> Yep, same here on a fresh checkout. And there was indeed a file
>>> missing from my check-in. Fixed at r2233.
>>> P.
>>> On Tue, Jan 13, 2009 at 7:02 AM, Obe, Regina
>>> wrote:
>>>> Mark,
>>>> Good thought. I can't remember if I did an autogen or not, but
just
>>> did
>>>> and my OpenSUSE is still compiling.
>>>> My MingW install which I did do an sh autogen.sh , configure, make
>>>> clean, make is failing with the same error
>>>> g++ -DHAVE_CONFIG_H -I. -I. -I../source/headers
>>>> -I../source/headers/geos -I../source/headers
>>>> -DGEOS_CAPI_VERSION=\"3.1.0-CAPI-1.5.0\" -DGEOS_JTS_PORT=\"1.7.1\"
> -g
>>>> -O2 -DGEOS_INLINE -Wall -ansi -pedantic -Wno-long-long -MT
>>>> libgeos_c_la-geos_c.lo -MD -MP -MF .deps/libgeos_c_la-geos_c.Tpo -c
>>>> geos_c.cpp -DDLL_EXPORT -DPIC -o .libs/libgeos_c_la-geos_c.o
> -g
>>>> geos_c.cpp -o libgeos_c_la-geos_c.o >/dev/null 2>&1
>>>> make[1]: *** No rule to make target `geos_ts_c.cpp', needed by
>>>> `libgeos_c_la-geos_ts_c.lo'. Stop.
>>>> Have you tried the latest one?
>>>> My next step is to blow out my geos source and start from scratch.
>>>> Thanks,
>>>> Regina
>>>> From: postgis-devel-bounces at postgis.refractions.net
>>>> [mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of
>>> Mark
>>>> Cave-Ayland
>>>> Sent: Tuesday, January 13, 2009 9:45 AM
>>>> To: PostGIS Development Discussion
>>>> Subject: Re: [postgis-devel] Can't compile Geos 3.1 under OpenSUSE
>>>> anymore
>>>> Obe, Regina wrote:
>>>>> I assume this is because of the recent changes. I did an svn up
> and
>>> a
>>>>> reconfigure and then compile under OpenSUSE.
>>>>> I get this error
>>>>> g++ -DHAVE_CONFIG_H -I. -I../source/headers
>>>>> -I../source/headers -DGEOS_CAPI_VERSION=\"3.1.0-CAPI-1.5.0\"
>>>>> -DGEOS_JTS_PORT=\"1.7.1\" -g -O2 -DGEOS_INLINE -Wall -ansi
> -pedantic
>>>>> -Wno-long-long -MT libgeos_c_la-geos_c.lo -MD -MP -MF
>>>>> .deps/libgeos_c_la-geos_c.Tpo -c geos_c.cpp -o
>>>>>> /dev/null 2>&1
>>>>> mv -f .deps/libgeos_c_la-geos_c.Tpo .deps/libgeos_c_la-geos_c.Plo
>>>>> make[1]: Leaving directory `/projects/geos-3.1.0SVN/capi'
>>>>> Am I missing something?
>>>>> Thanks,
>>>>> Regina
>>>> Hmmm the "ts" part implies this is something to do with the
>>> thread-safe
>>>> API patch. Perhaps you need to re-run autogen.sh so that it picks
up
>>> the
>>>> new files? Failing that does a brand new checkout work?
>>>> HTH,
>>>> Mark.
>>>> Mark Cave-Ayland
>>>> Sirius Corporation - The Open Source Experts
>>>> http://www.siriusit.co.uk
>>>> T: +44 870 608 0063
>>>> _______________________________________________
>>>> postgis-devel mailing list
>>>> postgis-devel at postgis.refractions.net
>>>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
>>>> The substance of this message, including any attachments, may be
>>>> confidential, legally privileged and/or exempt from disclosure
>>>> pursuant to Massachusetts law. It is intended
>>>> solely for the addressee. If you received this in error, please
>>>> contact the sender and delete the material from any computer.
>>>> geos-devel mailing list
>>>> geos-devel at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/geos-devel
