[geos-devel] 3.1.0rc1
Paul Ramsey pramsey at opengeo.org
Tue Jan 27 20:15:58 EST 2009
OK, answer is: maybe? The files are generated by ./configure as part of the
./autogen.sh; ./configure ; make dist
process, so they will appear in the tarballs. On the other hand, they
don't exist in SVN, so if you windoze developers checkout svn you need
some other way to get your hands on them... and bootstrap at least
makes that a bit faster. You could re-name it to autogen.bat? :)
P
On Tue, Jan 27, 2009 at 5:07 PM, Paul Ramsey <pramsey at opengeo.org> wrote:
> On Tue, Jan 27, 2009 at 4:56 PM, Mateusz Loskot <mateusz at loskot.net> wrote:
>> I've noticed that the README file is not very helpful for users building it
>> on Windows. Perhaps the notes from Wiki could be copied there?
> Done
>> Somet time ago I added boostrap.bat script and it is mentioned in
>> instructions on the Wiki. I see that version.h is provided in the package
>> and platform.h is generated automagically.
>> Does it mean bootstrap.bat is useless now? If so, I can remove its notes
>> from the Wiki.
> No idea. Does it? :)
> P.
