[geos-devel] 3.1.0rc1
Dane Springmeyer
blake at hailmail.net
Wed Jan 28 14:54:53 EST 2009
Hi Paul and Hartmut,
Sean wisely mentioned I should be careful in testing shapefiles with
invalid polygons, which I definitely forgot to think about since I was
reading in the shapefile directly.
Nevertheless with both this original shapefile [1] (that does have
invalid polygons) and a cleaned up version (with the buffer(0) trick)
that I have posted here [2], the below script results in the "should
never be reached" assertion.
Perhaps the cleaned up shapefile [2] is still invalid for passing
directly to the cascaded_union, just let me know how to test further.
Cheers,
Dane
[1] http://thematicmapping.org/downloads/TM_WORLD_BORDERS-0.3.zip
[2] http://dbsgeo.com/tmp/test_world_shapefile.zip
### python ###
from shapely.ops import cascaded_union
from osgeo import ogr
from shapely.wkb import loads
ds = ogr.Open('tm_world_buffer_zero.shp')
state = ds.GetLayer(0)
states = []
while 1:
f = state.GetNextFeature()
if f is None: break
g = f.geometry()
states.append(loads(g.ExportToWkb()))
print len(states) # 246
u = cascaded_union(states)
[....snip...]
cxx type MultiPolygon
cxx type Polygon
cxx type Polygon
cxx type Polygon
cxx type Polygon
Assertion failed: (!"should never be reached"), function itemsTree,
file AbstractSTRtree.cpp, line 358.
Abort trap
On Jan 28, 2009, at 10:33 AM, Paul Ramsey wrote:
> Dane, can you provide the shapefile? I will see if this reproduces in
> PostGIS and generate a test file for Hartmut if it does.
> P.
> On Tue, Jan 27, 2009 at 9:40 PM, Dane Springmeyer
> <blake at hailmail.net> wrote:
>> Hi again,
>> I just did a bit further testing of the new cascaded union goodness
>> via
>> Shapely. See the linked email below:
>> http://lists.gispython.org/pipermail/community/2009-January/001960.html
>> Seems that I reached where a point that 'should never be reached' ?
>> http://trac.osgeo.org/geos/browser/trunk/source/index/strtree/AbstractSTRtree.cpp#L358
>> I am new to looking at the geos code, so any pointers to help me
>> test more
>> would be great.
>> Thanks!
>> Dane
>> On Jan 27, 2009, at 9:02 PM, Dane Springmeyer wrote:
>>> Paul,
>>> I tested on mac 10.5 and ubuntu 8.10 and all configure;make and make
>>> installs went perfectly.
>>> Just a few compiler warnings that I've pasted here:
>>> http://dpaste.com/hold/113736/
>>> Dane
>>> On Jan 27, 2009, at 10:35 AM, Paul Ramsey wrote:
>>>> This is a pre-warning to PSC members to download and test the first
>>>> 3.1 rc tarball:
>>>> http://download.osgeo.org/geos/geos-3.1.0rc1.tar.bz2
>>>> If I don't hear any howls of dismay over the next 24 hours, I will
>>>> make a wider announcement for testing.
>>>> Paul
>>>> _______________________________________________
>>>> geos-devel mailing list
>>>> geos-devel at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/geos-devel
