[geos-devel] 3.1.0rc1
Paul Ramsey
pramsey at opengeo.org
Thu Jan 29 15:18:00 EST 2009
I can do an individual union of Mozambique and Zimbabwe without
problems. Should I be seeing a topology exception?
P
On Thu, Jan 29, 2009 at 12:09 PM, Martin Davis <mbdavis at refractions.net> wrote:
> When I look at the area of the reported TopologyException in OpenJUMP, I'm
> seeing the following kinds of vertex values:
> Feature ID: 122
> [ 3:0:666] POINT (32.476230999999984 -21.321853999999973)
> Feature ID: 222
> [ 0:144] POINT (32.476231 -21.321854)
> So the dataset is not actually 100% cleanly noded. These kinds of small
> discrepancies are exactly the kind of situation which used to cause
> robustness errors in JTS. This has pretty much been fixed by the addition
> of the Geometry Snapping concept. I think this made it into GEOS - but
> perhaps there's a bug in it?
> It should be possible to narrow down the problem by finding the two
> geometries which containing the problematic points and just working with
> them. (Mozambique and Zimbabwe)
> Paul Ramsey wrote:
>> Incidentally, the problem is not the invalid geometries. I first tried
>> the union after "fixing" them with buffer(0), but I just now tried the
>> union after deleting them, with the same result.
>> aggtest=# delete from tm_world_2 where not st_isvalid(the_geom);
>> NOTICE: Ring Self-intersection at or near point -53.7564 48.5033
>> NOTICE: Ring Self-intersection at or near point -70.9172 -54.7086
>> NOTICE: Ring Self-intersection at or near point 5.33694 61.5928
>> NOTICE: Ring Self-intersection at or near point 143.662 49.3122
>> DELETE 4
>> aggtest=# select geometrytype(st_union(the_geom)) from tm_world_2;
>> NOTICE: TopologyException: found non-noded intersection between
>> 32.4122 -21.2178, 32.4762 -21.3219 and 32.4762 -21.3219, 32.4122
>> -21.2178 32.4756 -21.3208
>> ERROR: GEOS2POSTGIS returned an error
>> aggtest=#
>> P
>> On Wed, Jan 28, 2009 at 1:49 PM, Paul Ramsey <pramsey at opengeo.org> wrote:
>>> For anyone that needs a test geometry, here's Dane's input as a single
>>> multipolygon:
>>> http://cleverelephant.dyndns.org/~pramsey/bigmulti.txt.bz2
>>> On Wed, Jan 28, 2009 at 7:44 AM, Hartmut Kaiser
>>> <hartmut.kaiser at gmail.com> wrote:
>>>>> I just did a bit further testing of the new cascaded union goodness
>>>>> via Shapely. See the linked email below:
>>>>> http://lists.gispython.org/pipermail/community/2009-January/001960.html
>>>>> Seems that I reached where a point that 'should never be reached' ?
>>>>> http://trac.osgeo.org/geos/browser/trunk/source/index/strtree/AbstractS
>>>>> TRtree.cpp#L358
>>>>> I am new to looking at the geos code, so any pointers to help me test
>>>>> more would be great.
>>>> Could you provide a minimal test I could use to reproduce this problem?
>>>> Regards Hartmut
>>>>> Thanks!
>>>>> Dane
>>>>> On Jan 27, 2009, at 9:02 PM, Dane Springmeyer wrote:
>>>>>> Paul,
>>>>>> I tested on mac 10.5 and ubuntu 8.10 and all configure;make and make
>>>>>> installs went perfectly.
>>>>>> Just a few compiler warnings that I've pasted here:
>>>>> http://dpaste.com/hold/113736/
>>>>>> Dane
>>>>>> On Jan 27, 2009, at 10:35 AM, Paul Ramsey wrote:
>>>>>>> This is a pre-warning to PSC members to download and test the first
>>>>>>> 3.1 rc tarball:
>>>>>>> http://download.osgeo.org/geos/geos-3.1.0rc1.tar.bz2
>>>>>>> If I don't hear any howls of dismay over the next 24 hours, I will
>>>>>>> make a wider announcement for testing.
>>>>>>> Paul
>>>>>>> _______________________________________________
>>>>>>> geos-devel mailing list
>>>>>>> geos-devel at lists.osgeo.org
>>>>>>> http://lists.osgeo.org/mailman/listinfo/geos-devel
> Martin Davis
> Senior Technical Architect
> Refractions Research, Inc.
> (250) 383-3022
