[geos-devel] [GEOS] #275: Topology Exception on valid geometries
geos-trac at osgeo.org
Fri Jul 3 06:21:54 EDT 2009
Reporter: yabo | Owner: geos-devel at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 3.1.1
Component: Default | Version: svn-trunk
Severity: Unassigned | Keywords:
I've encoutered a situation where two valid geometries (as stated by
IsValidOp) throw a Topology Exception when being unioned. The first
geometry is a MultiPolygon and the second a Polygon. Unfortunately I
couldn't shrink the geometries down to a human-parsable size.
I have this problem with both geos-3.1.0 and geos-svn-trunk.
The reported error is :
TopologyException: found non-noded intersection between -3138.99 39.9929,
-3195.93 131.777 and -3145.05 62.5969, -3138.99 39.9929 -3138.99 39.9929
I've attached the test program source to the ticket.
Thanks,
Ticket URL: <http://trac.osgeo.org/geos/ticket/275>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
