[geos-devel] 3.1.1rc1 and 3.0.4rc1
Obe, Regina
robe.dnd at cityofboston.gov
Fri Jun 12 07:51:20 EDT 2009
I looked at my computer the wrong way. You knew I would. I realized I
forgot to do a make check and make check still fails (why should I be
surprised :().
But I think its the redundant includes except the geos_c.h ones not sure
about look kind of serious.
Lots of errors like this
der'
../../capi/geos_c.h:805: error: syntax error before '*' token
../../capi/geos_c.h:805: error: storage class specified for parameter
`GEOSWKBWr
iter_setByteOrder'
../../capi/geos_c.h:807: error: syntax error before "handle"
../../capi/geos_c.h:808: error: storage class specified for parameter
`GEOSWKBWr
iter_getByteOrder_r'
../../capi/geos_c.h:809: error: syntax error before "handle"
../../capi/geos_c.h:811: error: storage class specified for parameter
`GEOSWKBWr
iter_setByteOrder_r'
../../capi/geos_c.h:816: error: syntax error before '*' token
../../capi/geos_c.h:816: error: storage class specified for parameter
`GEOSWKBWr
iter_getIncludeSRID'
../../capi/geos_c.h:817: error: syntax error before '*' token
../../capi/geos_c.h:817: error: storage class specified for parameter
`GEOSWKBWr
iter_setIncludeSRID'
../../capi/geos_c.h:819: error: syntax error before "handle"
../../capi/geos_c.h:820: error: storage class specified for parameter
`GEOSWKBWr
iter_getIncludeSRID_r'
../../capi/geos_c.h:821: error: syntax error before "handle"
../../capi/geos_c.h:822: error: storage class specified for parameter
`GEOSWKBWr
iter_setIncludeSRID_r'
../../capi/geos_c.h:829: error: storage class specified for parameter
`GEOSFree'
../../capi/geos_c.h:830: error: syntax error before "handle"
../../capi/geos_c.h:830: error: storage class specified for parameter
`GEOSFree_
r'
capi/threadtest.c:32: error: syntax error before '{' token
capi/threadtest.c:107: error: conflicting types for 'GEOSGeometry'
../../capi/geos_c.h:756: error: previous definition of 'GEOSGeometry'
was here
capi/threadtest.c:107: error: syntax error before '*' token
capi/threadtest.c:113: error: syntax error before "type"
capi/threadtest.c:181: error: conflicting types for 'i'
capi/threadtest.c:109: error: previous definition of 'i' was here
capi/threadtest.c:183: error: syntax error before "for"
capi/threadtest.c:196: error: redefinition of parameter 'GEOSGeometry'
capi/threadtest.c:107: error: previous definition of 'GEOSGeometry' was
here
capi/threadtest.c:196: error: syntax error before '*' token
capi/threadtest.c:198: error: storage class specified for parameter
`wkt'
capi/threadtest.c:199: error: syntax error before "FILE"
capi/threadtest.c:202: error: syntax error before "size_t"
capi/threadtest.c:205: error: syntax error before "input"
make[3]: *** [threadtest.o] Error 1
make[3]: Leaving directory
`/D/SVNProjects/geos/geos-3.1.1rc1/tests/unit'
make[2]: *** [check-am] Error 2
make[2]: Leaving directory
make[1]: *** [check-recursive] Error 1
make[1]: Leaving directory `/D/SVNProjects/geos/geos-3.1.1rc1/tests'
make: *** [check-recursive] Error 1
-----Original Message-----
[mailto:geos-devel-bounces at lists.osgeo.org] On Behalf Of Paul Ramsey
Sent: Thursday, June 11, 2009 9:29 AM
To: GEOS Development List
Subject: Re: [geos-devel] 3.1.1rc1 and 3.0.4rc1
I'm tempted to release on the basis of this news alone :) don't look
at your computer the wrong way, it might not work again...
P
On Thu, Jun 11, 2009 at 5:38 AM, Obe, Regina<robe.dnd at cityofboston.gov>
wrote:
> 3.0.4rc1 tar ball also seems to compile okay under MingW
> From: geos-devel-bounces at lists.osgeo.org
> Sent: Wednesday, June 10, 2009 12:16 PM
> Subject: [geos-devel] 3.1.1rc1 and 3.0.4rc1
> I have placed RC bundles on the download site:
> http://download.osgeo.org/geos/geos-3.1.1rc1.tar.gz
> http://download.osgeo.org/geos/geos-3.0.4rc1.tar.gz
> If I don't hear any bad reports or PSC vetoes in a couple days I will
> copy those files into actual releases. Change are largely back-ports
> of memory fixes from trunk and one nice little bugfix in buffer
> building (dropped multipolygon components) from trunk.
> P
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geos-devel
> The substance of this message, including any attachments, may be
> confidential, legally privileged and/or exempt from disclosure
> pursuant to Massachusetts law. It is intended
> solely for the addressee. If you received this in error, please
> contact the sender and delete the material from any computer.
