[geos-devel] 3.1.1rc1 and 3.0.4rc1
Obe, Regina
robe.dnd at cityofboston.gov
Fri Jun 12 08:00:07 EDT 2009
So in conclusion
make check on MingW -- 3.1.1rc1 -- barely gets in the door (I think it
passed one test before vomitting)
3.0.4rc1 make check -- chugs along for a while ang then geos_unit.exe
crashes with message
creating geos_unit.exe
.libs/lt-geos_unit.exe.c: In function `main':
.libs/lt-geos_unit.exe.c:79: warning: passing arg 2 of `execv' from
incompatible pointer type
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
