[geos-devel] 3.1.1rc1 and 3.0.4rc1 fail under VS 2008
Obe, Regina robe.dnd at cityofboston.gov
Sat Jun 13 12:10:00 EDT 2009
Paul,
Haven't tried 3.0.3 but the 3.1.0 tar ball fails too with similar errors.  I usually compile from SVN rather than the tar and I recall that passing but it was about 2 weeks ago i tried that.  Let me try compiling directly from SVN to make sure that works.  If so could be just the tar balls that are missing something.
-----Original Message-----
From: geos-devel-bounces at lists.osgeo.org on behalf of Paul Ramsey
Sent: Sat 6/13/2009 11:46 AM
To: GEOS Development List
Subject: Re: [geos-devel] 3.1.1rc1 and 3.0.4rc1 fail under VS 2008
Do GEOS 3.1.0 or 3.0.3 pass?
On Sat, Jun 13, 2009 at 8:41 AM, Obe, Regina<robe.dnd at cityofboston.gov> wrote:
> geos-3.1.1rc1 -- fails under Visual Studio 2008.  well at least for me
> anyway.
> 1) capi unit is still referencing GEOSGeomToWKB...  -  I think Mateuz said
> this should not be in 3.1.1 -- just in 3.2? I took it out, but everything
> still fails
> 2)badthreadtest.c, threattest.c, geostest.c -- have a big red mark -- saying
> they are missing CoordinateSequenceFactor.cpp among other things.
> 1>LinearComponentExtracter.cpp
> 1>c1xx : fatal error C1083: Cannot open source file:
> '..\..\..\source\geom\util\LinearComponentExtracter.cpp': No such file or
> directory
> 1>PointExtracter.cpp
> '..\..\..\source\geom\util\PointExtracter.cpp': No such file or directory
> 1>PolygonExtracter.cpp
> '..\..\..\source\geom\util\PolygonExtracter.cpp': No such file or directory
> 1>AssertionFailedException.cpp
> '..\..\..\source\util\AssertionFailedException.cpp': No such file or
> directory
> 1>IllegalArgumentException.cpp
> '..\..\..\source\util\IllegalArgumentException.cpp': No such file or
> directory
> 1>UnsupportedOperationException.cpp
> '..\..\..\source\util\UnsupportedOperationException.cpp': No such file or
> directory
> 1>geos_c.cpp
> 1>c:\projects\geos\geos-3.1.1rc1\source\headers\geos\io\wkbreader.h(151) :
> warning C4512: 'geos::io::WKBReader' : assignment operator could not be
> generated
> 1>
> c:\projects\geos\geos-3.1.1rc1\source\headers\geos\io\wkbreader.h(67) : see
> declaration of 'geos::io::WKBReader'
> 1>c:\projects\geos\geos-3.1.1rc1\source\headers\geos\geomgraph\nodemap.h(100)
> : warning C4512: 'geos::geomgraph::NodeMap' : assignment operator could not
> be generated
> 1>
> c:\projects\geos\geos-3.1.1rc1\source\headers\geos\geomgraph\nodemap.h(42) :
> see declaration of 'geos::geomgraph::NodeMap'
> 1>c:\projects\geos\geos-3.1.1rc1\capi\geos_c.h(710) : warning C4099:
> 'geos::io::WKTReader' : type name first seen using 'class' now seen using
> 'struct'
> 1>
> c:\projects\geos\geos-3.1.1rc1\source\headers\geos\io\wktreader.h(53) : see
> declaration of 'geos::io::WKTReader'
> 1>c:\projects\geos\geos-3.1.1rc1\capi\geos_c.h(711) : warning C4099:
> 'geos::io::WKTWriter' : type name first seen using 'class' now seen using
> 'struct'
> 1>
> c:\projects\geos\geos-3.1.1rc1\source\headers\geos\io\wktwriter.h(68) : see
> declaration of 'geos::io::WKTWriter'
> 1>c:\projects\geos\geos-3.1.1rc1\capi\geos_c.h(712) : warning C4099:
> 'geos::io::WKBReader' : type name first seen using 'class' now seen using
> 'struct'
> 1>
> 1>c:\projects\geos\geos-3.1.1rc1\capi\geos_c.h(713) : warning C4099:
> 'geos::io::WKBWriter' : type name first seen using 'class' now seen using
> 'struct'
> 1>
> c:\projects\geos\geos-3.1.1rc1\source\headers\geos\io\wkbwriter.h(67) : see
> declaration of 'geos::io::WKBWriter'
> 1>geos_ts_c.cpp
> generated
> 1>
> be generated
> 1>
> 1>c:\projects\geos\geos-3.1.1rc1\source\headers\geos\precision\geometrysnapper.h(96)
> : warning C4512: 'geos::precision::GeometrySnapper' : assignment operator
> could not be generated
> 1>
> c:\projects\geos\geos-3.1.1rc1\source\headers\geos\precision\geometrysnapper.h(45)
> : see declaration of 'geos::precision::GeometrySnapper'
> 'struct'
> 1>
> 'struct'
> 1>
> 'struct'
> 1>
> 'struct'
> 1>
> 1>c:\projects\geos\geos-3.1.1rc1\capi\geos_ts_c.cpp(156) : warning C4100:
> 'extHandle' : unreferenced formal parameter
> 1>Generating Code...
> 1>Build log was saved at
> "file://c:\Projects\geos\geos-3.1.1rc1\build\msvc90\geos_lib\Debug\geos_lib\BuildLog.htm"
> 1>geos_lib - 7 error(s), 15 warning(s)
> 2>------ Build started: Project: geos_c_dll, Configuration: Debug Win32
> 2>Linking...
> 2>LINK : fatal error LNK1104: cannot open file '..\debug\geosd.lib'
> 2>Build log was saved at
> "file://c:\Projects\geos\geos-3.1.1rc1\build\msvc90\geos_c_dll\Debug\BuildLog.htm"
> 2>geos_c_dll - 1 error(s), 0 warning(s)
> ========== Build: 0 succeeded, 2 failed, 0 up-to-date, 0 skipped ==========
> ________________________________
> The substance of this message, including any attachments, may be
> confidential, legally privileged and/or exempt from disclosure pursuant to
> Massachusetts law. It is intended solely for the addressee. If you received
> this in error, please contact the sender and delete the material from any
> computer.
> Help make the earth a greener place. If at all possible resist printing this
> email and join us in saving paper.
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geos-devel
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
URL: http://lists.osgeo.org/pipermail/geos-devel/attachments/20090613/af57efc7/attachment.html
