#271: Cannot access geos::algorithm
Reporter: xeriaz | Owner: geos-devel at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 3.1.1
Component: Default | Version: 3.0.3
Severity: Unassigned | Keywords:
Hello,
I have downloaded and built geos-3.1.1 according to instructions and
everything works perfectly. However it seems like I can only use member
functions from geos::geom, geos::io, and geos::util classes. When I tried
to use call functions from the geos::algorithm::CGAlgorithms, the compiler
gives "'algorithm': the symbol to the left of a '::' must be a type"
error.
Sorry I'm still new to GEOS, any help would be greatly appreciated,
thanks.
Ticket URL: <http://trac.osgeo.org/geos/ticket/271>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
